Question about Nintendo DS Lite Console
Ds will not turn on.power light is on,ds is fully charged.nothing comes on screen.
  • 277 Answers
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
4. While you're waiting, check the AC Adapter for the following:
? Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
? Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power issues, please continue reading:
? Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
? Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
? Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
? Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
? Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
? Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
? Once plugged in, check the power light on the Power button to see if the system is receiving power.
If the power is still continually shutting off regularly, please click here for repair options. For this particular symptom, it is best to include your Wii console's AC Adapter with your system. This will help our technicians ensure they are able to resolve your issue.
Posted on Aug 20, 2010
I have just brought a second hand ds lite, I have fully charged ds. When I turn power on the green light comes on put then turns off again. No image comes on screen.
you must have got it wet or mabee it has dust in it or mabee there is some damage inside take to a repair shop close by or the place you got the ds from and tell them your problem thats all i can do
Nov 24, 2010 | Nintendo DS Lite Console
Nothing working on screen when fully charged
Make sure all games and accessories are removed. If you cannot get it to work, you will have to get the unit services because you need the ds reset.
there is also a possibility that the motherboard is damaged or the IOS for the unit.
If this unit was modded in anyway, the unit could be in a bricked mode. Bricked means useless and a paper weight.
gl
Jun 13, 2010 | Nintendo DS Lite Console
My son's nintendo ds will not power on.
possibly, the battery went bad after overcharging...but is that supposed to be charging automatically? have the battery checked
Aug 11, 2009 | Nintendo DS Lite Console
Battery is fully charged but it still wont power up no lights when plugged in to charge
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
Jun 29, 2009 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
DS Powering On
Hi, if the bottom screen briefly comes on with a white screen. There is a issue with the top screen, it is either the top screen itself or if there is damage to the hinge it will more than likely be the cheaper option the ribbon cable that threads though the hinge to the top screens PCB board.
Mar 16, 2008 | Nintendo DS Console
Beyond Repair?
I would try and get a new DS if I was u
Jan 04, 2008 | Nintendo DS Lite Console
DS lite screens not coming on.
Is it definitely fully charged?
Dec 31, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
184 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
