Question about Harman Kardon HK695 Computer Speakers
No sound. Am I missing a cable? The speaker with the control knob has a wire that goes to the other speaker. It also has a brown cable that goes to the computer. There is a port for another cable. Do I need one here as well?
  • 20 Answers
Here's the link to the HK695 manual:
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
Follow the instructions to connect the sub and the satellites to the PC or laptop.
Hope that helps.
Posted on Aug 22, 2010
  • Ashley Dec 02, 2010
    Thanks!
95 Jeep Wrangler wiring harnesses broke down by color to show where each wire goes to
Car Radio Constant 12V+ Wire: Red/White Car Radio Switched 12V+ Wire: Purple/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Blue/Red Car Radio Dimmer Wire: Red/Black Car Radio Antenna Trigger Wire: N/A Car Radio Amp Trigger Wire: N/A Front Speakers Size: 4? x 6? Speakers Front Speakers Location: Dash Left Front Speaker Wire (+): Gray Left Front Speaker Wire (-): Yellow Right Front Speaker Wire (+): White/Red Right Front Speaker Wire (-): Brown/Red Rear Speakers Size: 4? Speakers Rear Speakers Location: Rear Roof Left Rear Speaker Wire (+): Gray/White Left Rear Speaker Wire (-): Brown/White Right Rear Speaker Wire (+): White/Black Right Rear Speaker Wire (-): Brown
Oct 04, 2016 | Crown Jeep Wrangler yj 95 94 93 92 91 90...
Trouble re-installing original radio to my 2005 Dodge Stratus, how many connections are there?
Here is a list.
2005 Dodge Stratus with Infinity Radio Wire Harness Colors
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Illumination Dimmer Wire: Orange/Brown
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: Dark Green/Red
Car Radio Amplifier Location: Amplifier is Mounted Under the Front Passenger Seat
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Dark Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Violet
Right Front Speaker Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Dark Blue/White
Right Rear Speaker Wire (-): Dark Blue/Orange
Sep 18, 2012 | 2005 Dodge Stratus
Wiring help for realistic 5 band equalizer cat.no.12-1963 don't know year or model of unit it has no wiring label on it. has 3 gray wires, 3white wires,3 green wires, one black wire,one brown wire....
the 5 thinner cables goes to positive lead of each speaker from the radio (input to amp) the red one to battery.You will not use the negative led for the speakers from the radio. The remaining coarse ones goes to the speakers (each pair same color to a speaker) and the red one feed radio positive led. Black is ground.
Jul 03, 2011 | Car Audio & Video
I have two wires going to my speakers for a 2007 silverado classic, brown & yellow? What is positive & negative
It doesn't actually matter unless the speaker is grounded on one terminal, however if you do get it backwards, you will have audio interference which may make things sound strange at times.
The general rule though is that the brighter color is positive, and the darker is negative.
This goes pretty much for any wiring system for speakers.
Apr 11, 2011 | Car Audio & Video
M-audio av20 right speaker has no sound coming out of it at all...
To troubleshoot the problem start with the bit that is working - the left speaker.
  1. Unplug the input leads on the back of the left speaker and swap them round.
  2. If sound now comes out of right speaker and not the left the problem is with your sound source (computer, IPOD or whatever) or the connecting cable is faulty.
  3. If there is still no sound from the right speaker try turning the volume control knob up and down quickly several times - does this produce any sound from the right speaker? Sometimes the electrical contacts get dirty and this can help clean them.
  4. Turn the speakers off using the volume control knob. Disconnect the speaker wire for the right speaker from the OUTPUT on the left speaker (push the red and black tabs downwards and gently pull the wires out. Find a small 1.5 volt battery (an AA or AAA size will do nicely) and touch the bare ends of the speaker wire briefly on the battery terminals. If you hear a slight crackling sound the wire and the speaker are okay and the problem is in the amplifier, which will need repair or replacement - not a job for an amateur.
  5. If you don't get any sound from the battery test find another piece of speaker wire (any piece of 2 core cable with bare ends will do for testing) and repeat the battery test. If you get sound then replace the speaker wire. If not remove the speaker wire again and go to next step.
  6. Lay the speaker face downwards and carefully unscrew the back panel (don't do this if it is still under manufacturers warranty - take it back for repair or replacement). Lift the back panel off carefully and slowly taking care not to pull the connecting wires inside the cabinet, which will probably be quite short. You may have to settle for just rotating the back panel slightly so that you can see inside if the wires are too short to do otherwise.
  7. Use sticky tape to tightly attach the bare ends of the speaker wires to the terminals of the battery. Touch the loose ends of the speaker wires on the two metal terminals where the internal wires are joined onto the back of the big loudspeaker cone. If this produces a crackling sound it is the internal wiring in the cabinet that needs re-soldering. Otherwise the loudspeaker unit has failed and will need replacement.
Jan 29, 2011 | M-Audio Avid Maudio 99005226600...
I need radio color wiring diagram for 2001 hyundai accent what wire goes where
Battery RED (+) RADIO HARNESS
Accesory WHITE/GREEN (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BROWN/WHITE
LF Speaker (-) BLACK/WHITE
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BLACK/YELLOW
LR Speaker (+) BROWN/RED
LR Speaker (-) BLACK/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BLACK/WHITE
Apr 06, 2010 | Car Audio & Video
Diagrama de arnes para conectar car estereo f65f-19b165-bd
si intiendes ingles un poco, aqui es los colores por los cables para estereo tuya..
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Nov 19, 2009 | 2000 Ford Windstar
Sound through right speaker is not proper Creative Inspire M2600
This sounds like an electrical problem in the speaker circuitry - between the speaker(s) and the control knob.
Jun 02, 2009 | Audio Players & Recorders
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
Harman Kardon HK695 Computer Speakers Logo
893 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
