Question about ASUS Laptop with Intel Centrino 2 Processor
I have a suss lap top model number X70L, the power socket is damaged and i am soldering a new one in. the problem i have is i do not know in which order to dismantal the lap top with out breaking any thing. hope you can help
  • 6,993 Answers
To dismantle your laptop, shut down the laptop, turn it upside down and remove the battery. While its still up side down, remove the Cd drive, use a screw driver that will fit into the screws to unscrew every screw under the laptop. Make sure all the screws are removed, then remove the Ram.
After that, use a flat screw driver to open the laptop cover from the side. The laptop cover is clipped together, so you will need to apply some force in order to gain access to the internal part of the laptop.
You might not need to open the screen part. But if necessary, check the screen part, you will see some small rubbers around the screen area, remove these rubbers and you will find the screen screws.
Note that you will need to apply force using a flat screw driver to open the laptop. And at the same time, be careful.
Good luck.
Posted on Aug 20, 2010
How can i fix my lap top battery circuit after fixing new cells?
A very dangerous thing to do and possibly the pcboard and temperature sensor inside the battery is now damaged. Probably cheaper to buy a new battery through ebay than purchase new cells to attempt a repair.
Nov 17, 2014 | Computers & Internet
I need to find out what ALL the sockets and other connections do on a toshiba MK1655GSX laptop hard drive does
Where the main sockets are (sata and power)there are four other pins on the right of the sata socket that seems to do nothing.i've seen it on other SATA HHd's but never been able to suss out what they do. i would like to fit a direct LED so i know when it is active with the RAID Ghost conection and e-sata 3 hyper drive .
Dec 22, 2013 | Taylor Made Flag Pole Sockets Surface...
I need to gain access to the ac adapter port because i dont have any power when i plug in thinking may just b needing some solder but cant get the dang thing apart any help would b greatly appreciated
On most screens there are rubber plugs that cover screws also underneath the lap top is screws which you have to undo in order to release the plates which are the power button plate as well as the keyboard plates be careful to remove components carefully and ground yourself before removing any parts. Always mark cables, fasteners so that you can remember where they go back to when assembling the parts back on the housing of the lap top.
You can now remove the board enough to get your component soldered in. I would also check and make sure that the power supply is not faulty as well before going to this extent of removing the board from the lap top. Also it would behoove you to just purchase a new board you can find those on EBay rather cheaper than factory boards will cost even know that the part is input plastic power port hole is almost the price of a refurbished board. If you go that route you will not have to solder or do the installation taking the chance of destroying the board anyway. That is what I would do personally at least research that option before going all out and soldering a component to the board. It is easy to ruin a board if you do not do it right. Also there are places with step by step video such as youtube.com just use keywords to find your video.
Jan 08, 2011 | Gateway M-7315U Notebook
I have a asus X70L laptop that has a damaged power socket, how do i dismantal the laptop to replace the socket
I answered this question for another brand of computer, but the solution is the same. This is a common problem, and the solution is not cheap or easy. The connector is soldered to the motherboard, or sometimes to a smaller auxiliary board. Either way, taking apart a laptop is not easy. This is a fix usually recommended for a computer shop. Sometimes it is not repairable, and a new circuit board is needed. Sorry for the bad news.
Aug 11, 2010 | ASUS Laptop with Intel Centrino 2...
Have acer aspire 3690 - power socket is detached from board and some of the connecting tracks directly to the socket are damaged/missing - Have replacement socket but at a loss with regards to connecting...
Use epoxy glue to fasten the socket to the board. I assume that you have a proper soldering iron (small grounded tip, not a soldering gun), and know how to use it. After the epoxy has cured, trace the damaged tracks back to another solder connection, then solder an insulated (about #24 or #26) wire to that point and to the appropriate connection on the power jack. There should be a maximum of three wires to install. If you make the proper connections, it should work as before. Good luck!
Feb 05, 2010 | Acer Aspire 3690-2196 Notebook
Lap top not charging . purple light is not on. is it battery or charger?
the charger lasts longer than the battery .you need another lap top battery
Oct 16, 2009 | Computers & Internet
Battery charger fine but lap top shows not charging
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 10, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Where can I procure parts for a WF203 model TV. The part that receives the coax cable is broken and I need to replace it
Try ued.net you'll need make and model numbers, depending on how old tv is it could be either a antenna isolator or a tuner.
Aug 05, 2009 | Televison & Video
No power to motherboard, need to open laptop, have removed all screws but cannot open ! need to solder power socket
most lap tops are put together in a way that u need to use a small screwdriver prefably flat and gently prise at tae seem around the edge of the lap top hope this helps you.
Jun 21, 2008 | Computers & Internet
ASUS Laptop with Intel Centrino 2 Processor Logo
75 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
