Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Ebook 320 external hard drive
During instalation the power went off and now my computer won't recongize the g drive. It says it was removed from my computer. Help
  • sekarnaren Jan 25, 2009
    i connect the external hard drive 320 mdl wd25001032 the systemdesktop window xp will not recoganise and shows un known device.
  • Anonymous Mar 18, 2009
    the external hard drive is not recognized by my computer.
  • 19,396 Answers
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Posted on May 21, 2009
Wd3200 aajs external drive light flashes and won't come on.
Get a new case and transfer the hard drive to the new case. You can get cases at any store that sells computer parts and several places online.
https://www.walmart.com/c/kp/external-hard-drive-enclosures
Sep 25, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
We understand that your problem is: hello i was using my buffalo ministation 320 gb external hard drive about a week ago, it was working fine but I left it on my bed when I was done. About 2 days later I...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Buffalo Technology 320GB Ministation...
Internal 320 hard drive into external
If you got a USB casing for that, it would have come with a USB and power cable. Yes, power too!
Plug the power, and make sure you have a USB 2.0 hi-speed port. Also check "computer management" and check the hard disk works.
May 24, 2010 | Western Digital (WD3200JS) 320 GB Hard...
My computer hangs when I start it up until I remove the WD 320 GB External USB connection - then it will restart ok. I have to then reconnect the hd. - what can I do about this?
It sounds like it is trying to boot from the external drive, go into the BIOS settings and disable boot from external device and see if that cures it.
Mar 30, 2010 | Western Digital Elements powered by WD 320...
WD 1tb, lost the partion with the startfiles and now it won´t find the drive. What can I do?
go to computer mangment and u will see drive there in hard disk option
format ur hard drive if u dont have any imp data and it will start working again
Oct 02, 2009 | Western Digital Elements powered by WD 320...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
How to load pictures,ebooks onto my passport elite 320 gb
Copy and paste my man. There's no quick fix to it. I suggest you make a folder for pics, ebooks, etc. Then just transfer the folders onto your hard drive.
Feb 17, 2009 | Western Digital Passport WDXML800UE...
My computer does not recognize my Western Digital (WD3200C032) External Hard drive. The hard drive orignally worked fine. Then one day 3 separate computers would not recongize when the USB was plugged into...
if u are using a external hard disk case with the normal hard disk
try connecting your hard disk with a new casing.
if it is made as a external hard disk change the cable .
because after a few time usage the cable will not be quite good as new.
After inserting the usb cable in your pc if it shows any warning
information, or any message just give me that too for exact solution
Dec 15, 2008 | Western Digital (WD3200JS) 320 GB Hard...
I accidently used a different plug for my Book
maybe it is a goner,maybe the volt,amp, where too much for the device
Mar 14, 2008 | Western Digital 320GB MyBook External USB...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
899 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
