Question about Sansui Audio Players & Recorders
DRIVE BELT FOR SANSUI TURN TABLE - Sansui Audio Players & Recorders
We need a belt for a Sansui turntable sr-2050c.
Posted on Jun 10, 2008
Rockola 442 turn table turns to slow
Not familiar with this model but if it is belt driven, replace the belt. If it is not belt drive then there is a voltage regulation problem. Check for fault capacitors first and work on from there. If you can find a manual online this will assist in the fault finding as voltage reference points will be indicated on the schematic. Good luck. Cheers
Dec 15, 2016 | Saws
Toshiba Stereo Music Centre SM-D30,Turn Table, SX-N330 Speakers
Try:
http://www.vintage-electronics.net/toshiba-sr-f225-belt.aspx
If the turntable has a two-piece platter, Lift off the outer platter and place the belt around the inner platter and motor pulley.
If the turntable has a one-piece platter, lift off the whole patter, place the belt around the inner drum. There will be a hole in the platter's top through which you can reach a finger to stretch the belt so that the belt can be placed around the motor pulley as you put the platter back in place.
Aug 25, 2014 | Audio Players & Recorders
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
Where do i get the belt that opens and closes the disc holder for a C1 CD-V1000 thanks
If you already have the belt you can use internet resources to track down a spare parts wholesaler to obtain a replacement belt. I hope this helps. Good luck.
Feb 08, 2011 | Sansui Audio Players & Recorders
While cutting , i experienced a bind. Before the saw stopped I shut it off. Left overnight, now will not restart. I have pushed the thermal reset button, however it does not seem to engage. I have checked...
Is this a direct drive or belt drive saw? If belt drive, you can remove the belt and try spinning the motor by hand then turn it on. Sometimes they can get stopped in a dead spot. Do not get your hands/fingers in the way when turning it on. You may need all of them someday.
Aug 08, 2010 | Hitachi C10FL 10" Stationary Table Saw...
My turn table does not spin...please help
It sounds like the belt drive on it... These get stretched and dont have enough tension to turn the table from the motor. In a pinch I have used a rubber band. You could check with a local record shop and find out if they could order a replacement belt by bringing it in to them ...hope this helps
Apr 19, 2010 | Crosley 0187SST Turntable
How do you replace the belt?
Lift off rubber table mat..then lift off turn table..belt will then be visable..Advise: belt may not need replacing.. check that it has`nt just come off the drive motor..!
Feb 26, 2010 | Audio Technica AT-PL50 Turntable
Saw motor runs but blade does not turn, nor is it loose. I realize it is direct drive (ie not belt driven) - any ideas as to problem and solution?
I actually asked that question as a skeptic. I've never seen a direct drive table saw in 25+ years as a cabinetmaker... But I'm glad you got it solved!
Apr 20, 2009 | Saws
125 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
