D Llink 1 604 router has no reset button and is not working
    Guru:
  • 1,342 Answers
It should be a little pin hole on the back of the router that you can stick a paper clip or pen into. Hold it in for about 10 seconds to reset it.
Posted on May 03, 2008
Reset button location
To perform a hard router reset, keep the router powered on. Then, find the unit's reset button, often located on the rear of the device. Use a pen tip or bent paperclip if necessary to depress the button and hold it down. Network administrators are taught to hold the button down for 30 seconds; your router probably does not require waiting that full length of time, but this is a good general rule to follow. After releasing the hard reset button, a router may need up to 1 minute to reboot and resume normal operation.
An alternative method for hard resets involves holding the reset button down for 90 seconds instead of 30, unplugging the router from power and then re-plugging it partway through as described in these instructions for the 30-30-30 hard reset rule. This more involved reset process may not work on some routers and should only be tried if the basic 30 second version does not work.
To avoid Internet connectivity complications, disconnect the broadband modem from the router before performing hard resets.
Mar 01, 2014 | Computers & Internet
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Cannot remember log in info
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
Cant log on to router
If you have forgotten your router's password, please follow the instructions below to resolve your issue.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router's web-based setup page. Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. Any settings on the router will be erased and the router's IP address will become "192.168.1.1," the username is still blank, and the password will be "admin."
To perform a hardware reset on your Linksys router follow the steps below.
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
3798-001.png Figure 1: Location of the Reset button of a Linksys BEFW11S4 router.
NOTE: If your router does not look like this, refer to the other images below:
4030-022.png Figure 2: Location of the Reset button of a Linksys WRT54GX router.
4030-024.png Figure 3: Location of the Reset button of a Linksys WRT54GC router.
NOTE: If the image of your router is different from the ones shown above, please consult your router documentation.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
Step 1:
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Administration then Factory Defaults.
4008-003.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Look for Restore Factory Defaults and select Yes.
4008-005.png Step 4:
Click 4268-009.png.
Nov 11, 2010 | D-Link DI 514 Wireless Router (DI-514)
My power light on my Netgear WGR614 wireless router keeps blinking & will not allow me access to the internet.I have unpluged it, pressed the reset button & the light keeps blinking.Any thoughts?
Maybe you had a power surge.
The reset button does nothing with the router powered off, basically you hold the reset button in for 30 seconds with the router powered on. Following this you will need to set up the router again as all settings will be reset to factory defaults, from the sounds of it though the router may be dead.
Another reset method is as follows;
1. With the router powered off hold in the reset button,
2. Keep the reset button in, power on the router, wait 30 seconds,
3. Keep the reset button in, power off the router, wait 30 second,
4. Release the reset button.
Did you have wireless disabled?
If you have access to a multimeter check the PSU is working correctly.
Jan 27, 2010 | NetGear WGR614 Router
Power light blinking not working cannot re set
Was there any power flicker before it happened?
1. Reset the router by pressing the reset button of the router for 15 seconds while the power cord is plugged in and while the router is powered on.
2. Release Reset button after 15 seconds and unplug the power cord of the router then press the reset button again for 15 seconds.
3. After 15 seconds release the reset button and replug the power cord then press the reset button again for 15 seconds.
If this didn't work.
1. Plug the power cord to the router, and unplug it do this 7 times then reset for 15 seconds while it's unplugged and plug it back it and press the reset button for 15 seconds and release it. Try to check if there's any changes.
Jan 09, 2010 | Linksys Wireless-N WRT150N Router
I can't reset my cwr-854 router by pressing the RESET button for more than 1 minute and nthing happens , either in Power ON and OFF
You can reset this Wireless Access Point by clicking on Reset button, and then press OK button to confirm your decision.
Note: you can also hold down the reset button for more than 10 seconds to reset its default settings back to factory default.
If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
Oct 20, 2009 | Cnet (CWR-854) Wireless Router (cwr854)
My new linksys router doesn't allow me to print
Try deleting the printer from the PC then browse for network printers and set it up again....
Mar 12, 2009 | Linksys WRT160N Wireless Router
Reset router
Howdy,
Please try the reset button again. Make sure the ROUTER IS POWERED ON and hold the reset button in for 40 seconds. Then unplug the power cord for 1 minute and then reconnect & restart. If that still does not work then:
Logon to router 192.168.1.254
You will be on Home Summary tab.
Go to Diagnostics tab and click on Reset Device button on right side.
This will accomplish the same as pressing the reset button.
Simply unplugging the power cord will not reset the device.
Good Luck,
J
Jan 20, 2009 | Westell Wirespeed VersaLink...
Router reset
the power light of your router should go flashing once it's being reset. If it is not doing that you can try this reset.
Hold the reset button for 10 sec. while holding the reset button unplugged the power of the router, wait for another 10 sec (still holding the reset button in), plug the power back and wait for another 10 sec. and now reslease the power button.
If it still won't work you can also do a software reset with the latest version of this router, You go to the setup page and go to the administration tab and go to the sub tab that says factory defaults, just tick yes and do save settings.
Hope this one helps.
May 09, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
