Question about Kyocera Mita Office Equipment & Supplies
This question refers to a Kyocera copier KM 1530 (not to a Panaosnic copier, as indicated in your questionaire - it was not possible to change this!): when the "add toner" and the "toner disposal" indicators lit, I continued copying, until the indicator "memory overflow/data error" lit - and no more copying was possible. Then I replaced the toner cartridge and the toner disposal tank by original ones. After restarting, all three indicators lit again, no copying is possible. I tried copier off, copier on, unplugging the copier - no result. What should I do? I have good knowledges in repairs, if I receive a step-by step instruction.
  • 1 more comment
  • imcgmbh Aug 21, 2010
    Thank you so much foir replying. However, can you tell me in which section I can find U13? IIn the manual, I do not see any page numbers, only sections, and it takes very long time to look through the manual (I am using MAC OS 10.4, Browser Firefox).
  • imcgmbh Aug 23, 2010
    Dear ZJLimited,
    I got page 75 yesterday. Sorry to bother you again:
    when trying to enter in maintenance mode (according to 1-4-1, the following happens:
    After starting the copier, I pressed "Start". The display shows "1".
    With the numeric keys, I tried to enter "10871087", but after having entered "10871, "250" appeared. After continuing with"1087", "U000" flashes. When I then enter e.g. "131" and then press the start key, the display changes to "164" and nothing happens.
    The three error indicators still are lit.
    I am sure, I do something wrong, but what?
    Supposed that I would succeed in performing to enter the requested maintenance step, please tell me, which number is the correct one for my case. Certainly, what is necessary, is to reset the memory and/or the data memory. But: I am afraid that I might do the wrong step with a questionable result when I do not perform the right maintenance step.
    Please accept my apologies for asking you again to help me. It seems to me that you have the expertise to bring me to a good and I hope that you don´t give up until I send you a "hurrah" message.
    Kind regards.
    imcgmbh
  • imcgmbh Aug 25, 2010
    08/25/10:
    Dear ZJLomited,
    I am urgenly waiting for your reply. Please help me!
    Regards,
    imcgmbh
  • 17,970 Answers
I suggtes check the Service Manual U13x section (page 75 and next), this fault are refer to the toner calibration or reset, after any new inatallation.
KyoceraMita-KM-1530-2030-Service-Manual
Hope helps.
Posted on Aug 20, 2010
  • 1 more comment
  • ZJ Limited
    ZJ Limited Aug 23, 2010
    When ths site link is open, just write 75 in the bottom toolbar page, then this page appears in there...
    Good luck.
  • imcgmbh Aug 24, 2010
    Dra ZJLimited,
    as I did not receive a confirmation of my mail sent to you yesterday, I will try again, sending you the same message again:
    Dear ZJLimited,
    Kind regards.
    imcgmbh
  • ZJ Limited
    ZJ Limited Aug 25, 2010
    Its so rare. After that the first "maintenance code" is enter, are you selecting the right maintenance item?
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Km 1530 displaying ap on screen
Please click here to download the technical guide and user manual.
http://www.kyoceramita.eu/index/service/dlc.false.driver.KM1530._.EN.html#
Sep 06, 2012 | Kyocera Mita Office Equipment & Supplies
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Possible solution for kyocera mita km-1530 c610 error?
This is temperature error code. For causes and solutions see this: C6100, How to reset
Feb 16, 2012 | Office Equipment & Supplies
Dear sir i need to service manual for mita km-1530 with regards oskooie
pls go on this site
www.azmanual.com/manual/.../kyocera-mita-km-1530-manual
Dec 12, 2010 | Kyocera Mita Office Equipment & Supplies
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Dec 10, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
211 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
