Question about Health & Beauty
My dog always makes my carpet wet... What should I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
You need to take him outside every few hours and wait for him to go, for a number of days. Even if nothing happens reward him with a treat,
If you cant always take him out side , he will need a tray with paper in it,
as he gets older he will wait longer between toilet trips, and will bark or scratch to get out.
Posted on Aug 22, 2010
What products will remove dog wee stain from a carpet?
  • Dog liquid waste turns to crystals when it dries,, the only way to get the crystals out is with hot water extraction. If you use too much water you run the risk of it getting into the padding or the backing of the carpet and then it smells till it dries out. You need to get a carpet shampoo or cleaner that has enzymes in it.
May 05, 2017 | Vacuums
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell carpet steamer not working
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
THE CARPET UNDER THE DRIVERS SIDE IS ALWAYS DAMP TO WET CLOSER TO THE DOOR AND MIDDLE OF CARPET, WHAT COULD MAKE THAT HAPPEN?
If you have a sunroof that would be most likely the problem. If not you may have a bad seal in door or windshield.
Oct 06, 2009 | 2004 Jeep Grand Cherokee
Wont **** up very much and know my room smells rotten
Even the professionals have problems getting pet stain smells out of carpeting. You need to use a good deodorizer and get the carpet as dry as possible.
Aug 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro Heat 8910 clogged?
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Nov 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
How to get rid of dog smell
I had this problem along with a clogged filter. I used the solution for clogged filter here on Fixya and the dog smell went away too. It has to do with the flange on the cylinder getting pushed up out of position. Give it a try.
Oct 24, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
