Question about Dell Latitude D520 Notebook
My Dell Latitude D520 has a black LCD screen. An attached external monitor works fine, so there is nothing wrong with the actual processor. I sthere anything I can do to fix the screen?
    Scholar:
  • 166 Answers
Definitely there is nothing wrong with your with your computer but the LCD components only. If your computer still under warranty, I suggest you contact Dell Technical Support so you don't need to spend. However, if you are not sure go to http://support.dell .com ad provide your service tag which you can find underneath/bottom of your notebook. Please post your comment if the information provided has been helpful that could help move to the next rank and further improve my support assistance. Thank you and regards.
Posted on Aug 20, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Definitely the problem is with the LCD screen... Contact Dell if you are stii under warranty or else please replace the part with the help of a local tech.. Replacing a part for a computer that is out of warranty is costly in dell.. They would charge you more....
Posted on Aug 22, 2010
I have the same problem as this one does. my monitor goes black when windows boots. I can see the computer load at fist, then when the window icon shows. the screen goes black. WHY ?? im thinking there is...
you can try Fn + F8 and see if the display was toggled for external (Wait about 15 seconds before pressing a 2nd time) that is the keystroke from (LCD, External, LCD and External)
If no go, see if your system keeps video displayed in the safe mode (F8 at boot, select Safe mode from the boot menu)
you can also run diags on the LCD (Power button + D) or PSA diagnostics and see if the video stays on out of the operating system (Power +Fn)
Jul 21, 2011 | Dell Latitude D520 Notebook
I have a dell latitude d520 and when i turn it on it starts with the dell screen and then a black screen with a little white line top left and then nuffin iv tryed to do wat shibuda says do with the...
Have you tried an external monitor to see if the screen is faulty?
The fact that the DELL screen comes on shows that the bios is running. Try pressing F2 to get into the bios and reset to defaults.
Feb 20, 2011 | Dell Latitude D520 Notebook
The bottom 1/3 of the screen is blanked out although the machine is totally usable I can't see anything below the blank screen. It will then clear and I can work normally and then the same portion of the...
Hi friend, In this case I would recommend you to connect any external monitor to the laptop and check if you have the same issue on the external monitor as well. If the same issue occurs on the external one than we can try installing the latest video drivers for the same'
If the external is fine, then i would recommend you to please change the LCD of the laptop
Dec 08, 2010 | Dell Latitude D520 - Celeron Intel Celeron...
My Dell Latitude D630 will power on but the screen is black....nothing will show not even the startup page for windows. What do you think the problem may be
I would suspect either the video card or your LCD screen.. A good test is to hook up an external monitor and see if that works. Be aware that when you start it up, you will have to hit the function key and special function key combo to switch it to the external display.
On the latitude, that is the Fn key plus the F8 key.
Mar 22, 2010 | Dell Latitude D630 Notebook
Dell latitude d610 dark screen
there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly  you should go to service and need to be changed INVERTER.
pls rate
May 28, 2009 | Dell Latitude D610 Notebook
LCD dim.
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
May 23, 2009 | Dell Latitude L400 Notebook
My dell latitude d520 was working fine and now when I am on my screen starts running lines from left to right across the screen and then goes blank or black and sometimes comes back on and sometimes it...
if you tap the back of screen and it goes on and off chances are its loose ribbon cable ,
every time you open and close lid , it will tug on it a bit, if the light goes off then inverter problem
Mar 10, 2009 | Dell Latitude D520 Notebook
Dell Latitude C810 LCD screen doesn't work
buy an inverter off ebay. they are cheap and good. 10 dollars
Jan 07, 2009 | Dell Latitude C810 Notebook
DEll Latitude D600
The back lighting for the LCD panel has gone out. The picture is there, you just can't see it without the backlighting. So, it could be the Inverter that supplies power to the back lights or it could be the CCFT lamps that burned out. In either case your local computer repair shop should be able to fix it. If it is still under warranty take it back to where you bought it and they should have it repaired under warranty.
Aug 04, 2008 | Dell Latitude D600 Notebook
Dell Latitude D520 Notebook Logo
386 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
