Question about Skil Saws
How do you turn the Vari-Orbit Settings knob? Mine wont turn & I don't want to force it, but I need another setting for plastic. Is there a release mechanism that has it locked in at present? It is a Skil Auto Scroll Vari-Orbit Jig Saw model 4395 1/3 HP
2 Suggested Answers
SOURCE: task-force-4-amp-jig-saw
how do i change blade on task force jig saw. i am un able to pull it out after pressing button for it
Posted on Jul 01, 2010
I have a 3 gallon air compressure that wont go above 40 psi
Mine has a little knob to turn to set the pressure. Mine is set at 120 lbs. Probably yours is set so tire pressure won't go over 40 but there should be a setting to set it what you want.
Dec 04, 2014 | Psi Air Tools & Compressors
Car stereo just randomly stop work doesnt allow me to turn up volume or change stations or set it to aux none of the buttons work but the stereos turns on.. what could it be???
Well knowing what stereo you have would help, but mine, the volume knob doubles as the settings knob if you press it. In some newer systems like mine, you should find a "back" button (small arrow) like on a cell phone. Trying using that to escape the settings mode that you might have activated.
May 28, 2014 | Car Audio & Video
My garage door opens about 6" then stops
It sounds like you need to adjust the force settings on your opener. You should see either a white plastic knob on the opener, or a screw adjustment labelled "Open Force" or "Open Sensitivity". If you adjust that, it should fix the problem. If not, you'll need to contact a repair service.
Sep 16, 2013 | Sears Craftsman LiftMaster Chamberlain...
Orbit 57004 sprinkler controller does not turn on valves in Auto mode. Works OK in manual mode. All settings were checked carefully and repeatedly and verified by Orbit tech assistant by walk through
I am experiencing the same problem with my Orbit 57004. Did you ever figure out what was causing it not to start in "Auto" mode? he solutions above are not panning out for me.
May 12, 2012 | Hardware & Accessories
Marshall mg100fx treble knob does not automatically kicks in when amp turned on?
Are you old enough to remember when amps were all linear? Well, this is a computer. I haven't seen the schematic, but I'd guess the knobs are not connected to pots, but rotary encoders which send signals to a processor board to change settings. So, it's either a bug or a "feature" that causes these settings to start at zero when you boot the machine. You may be able to store all the last settings in memory so they start there.
Apr 05, 2017 | Music
I took off the grind settings knob on my Bunn G2 grinder... and now it won't grind!
oooooooooppppppppppsssssssssssssssss
you should not do this
the knob keeps two burrs together .The knob forces the screw (when you turn for grinding quality).
and adjust burrs far and close as needed
.reinstall it and turn the knob to the right until you feel tightness.Then,turn to the left 3 turns. and then adjust the grinding quality whatever you like .
thanks
please rate my work
Apr 27, 2011 | Bunn -o-Matic G2 (2 lb. Commercial Coffee...
How do I remove & replace screen on Xda orbit.
I used a T6 Torx screwdriver, a piece of flat strong plastic (other people have suggested old credit cards), and a small flathead screwdriver (but not essential).
1) After taking the battery out I also removed the SIM card, the memory card, and the stylus
2) This picture shows the first screws to remove (circled in red), by using the torx
3) I then levered the hole the stylus fits into, by prising up with the end of the stylus (to remove the back cover)
4) Using the plastic tool I slid it around the edge, being careful not to put to much force into it to remove the rest of the clips around the back cover.
This is a picture of the back cover off with the locations of the clips (note the camera hole for orientation)
5) I then removed the next set of screws (with the torx again)
6) I then removed the middle cover by prising against the front (the front was connected to the circuit), I found if it didn't want to release in one direction, then I would tackle it from the other way round
7) Then to prise off the front cover was straight forward by using the flathead to lever the two clips in red
** The connector circled in yellow is for the front button set, and I didn't need to remove this to change the screen **
8) I then removed the flexi circuit connecting the screen (circled in blue) - I did tear mine, but that is fine for me as the screen was broken anyway, so if I was to do it again I would take more care
This shows the front cover with the clips circled
9) The screen was held on with two strips of sticky tape, and I just used the flathead to prise it away
Connecting the new screen back was straight forward, as was putting the phone back together once I knew where the clips were. I did need to make sure the volume button was lined up with the connection on the circuit however.
If the links don't work go here
Hope it helped.
Nov 26, 2009 | O2 Xda Orbit Smartphone
I have an xploid 760 same amp wit ha 800 watt sub. eb=verything should work fin. but the same prob when i turn up the valume the overcurrent kicks on
use a bigger ground wire for amp and protect mode will stop clipping and shutting amp off also make sure power wire and ground wires aren't the same size ground bigger .............if this doesn't help change settings on amp to lower power
easiest way to set amp is (turn the knobs on amp all down turn up your system to the level you listen to normally and then set the amp knobs for bass turn knob slow to set properly but i think the ground needs to be bigger and maybe moved to a new location
hope this helped
Mar 03, 2009 | Sony XM-2150GSX Car Audio Amplifier
Washer not spinning
my ge top load washer washes but wont spin at end of cycle to ring the clothes out. if i mess around with the switch or motor wire connections it starts to spin with some help
Jan 05, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Sound volume
hi there are 2 options for this: 1) if its a anlog knob then the AMP inside is gone bad... 2) if its a digital knob then it is preesed constantly and there for raising the volume level try disassemble the system and making the spring knob more efective good luck
Dec 28, 2005 | RCA RS2652 Shelf System
Saws Logo
73 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
