IT SAYS IT'S A MOVEMENT WATCH, IS THERE A BATTERY
    Sergeant:
  • 179 Answers
Such watches produces electric from movement and stores in some storages, some of them, stretch a winder to keep watch working.
Posted on Aug 20, 2010
New batteries control lights up no movement. Help
Presuming the watch and the battery are both in working order there is only two things it could be:
1. (Unlikely) the battery is incorrectly fitted i.e. wrong way up.
2. (Very likely) the movement on the watch will have two points which have to be shorted out (Joined) momentarily in order for the movement to start, they should be marked on the movement, further advice not posible due to so many movement variations.
Feb 21, 2017 | Watches
Tip
LOST SOUND AFTER BATTERY REPLACEMENT.
If you experience no sound (alarm) from your watch after battery replacement, that means the coil spring fell out of watch while the battery has been replaced. Coil spring is transmitting vibrations from watch movement to the sound membrane at the back cover of watch, and if it is lost, there is no physical body to transmit signal, thus no sound. Coil spring itself is quite tiny and can be easily lost without even noticing it, mostly because it is not soldered to the watch movement or sound membrane and as soon as the opened watch is turned over, the coil spring fells out. If you are not able to find the coil spring in/around the place where the battery change took place, there is no other solution but to visit your nearest watch repair shop and ask to fit new one. In case if you are lucky enough to find the coil spring, fit it back in to appropriate hole in watch movement inserting out-bent end into movement. In most watches coil spring holes are marked: C.SPRING/COIL SPRING/ C.S or similar. Hope it helps.
on Mar 31, 2010 | Watches
What battery is in the DKNY Ny Twist watch?
I had to look into this for my wife's DKNY watch and this particular model has a Ronda 751 quartz movement, which takes a 379 battery. You can verify this by entering the movement name 'Ronda 751' and you'll see pictures of the movement with a 379 battery inserted.
Jan 07, 2014 | DKNY Ny4634 Twist Watch
Watch stopped working 11 months after purchase. New battery fitted - watch stopped couple days later. Another new battery fitted (both by jewellers). Again, the watch stopped within 2 days. Can't find a...
It is best to go to a watchmaker for this issue. If the battery was improperly installed, it can damage the movement or contacts, which will mean the movement must be replaced. We see this issue often. Another common problem is that the oils from the installer's fingers may be causing a bad connection if the battery and the contacts are not properly cleaned. We would use the Pulse test to see if the watch has current, if so, the movement is bad mechanically, it must be replaced. If it has no current, we would check and clean all connections and replace the battery. If there is still no current (using Pulse diagnostic) then the movement is bad and it must be replaced.
Jan 19, 2011 | Tommy Hilfiger Sport Stainless Steel with...
What is the main internal assembly of the Casio forester watch called? Replacing the battery does not work.
mcdevito75 here, The Internal workings of all watches and clocks, Quartz and mechanical is called the movement. You may have a weak or even dead battery, even if the battery is new. If you"ve dropped your watch, got it water logged, you could have hurt the Quartz movement. It'll take special equiptment to check the Quartz movement to see if it"s burned out. I would try another battery or at least double check this batteries instalation in your watch. For more info, here is Casio"s contact number, 800-435-7732 9AM--5PM EST.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
Watch not working!... no use if i put a new battery..... the guy says i had to change the battery immediately and now my watch got spoilt by the old battery.....it seems it leaked and spoilt...... now how...
mcdevito75 here, Sadly, once a battery, any battery leaks, it leaks out acid that eats away metal. Once your watch Battery leaked acid, it ate away electrical contacts, wires as thin as hairs, and tiny linkages with--in the quartz movement of your watch, ----- there is no reversal of this acid corrosion. You have 2 choices, 1 and if this is possible, have your watch repair person replace the quartz movement with a new one, if replacement movement is available, and 2 replace the entire watch. Sorry.
Jul 10, 2010 | Armitron Digital Sport 406623BLK Watch
MY WATCH JUST STOPPED RUNNING. i THOUGHT IT WAS THE BATTERY BUT i HAD THE JEWELRY REPLACE IT AND STILL NOT WORKING. oF COURSE WARRANTY OUT!
Of course the problem may be with the movement, but, if I was working on your watch I would carefully inspect that the battery was put in right and second I would check the conditiion of the battery. It is always possible that the battery may too old. They d have a shelf life. Also, if I were working on your watch I would be able to test the movement to see of the gears in the movement were stuck because of gummy oils, etc. I have the equipment to unstick a movement. The bottom line maybe that you will need the movemet replaced as this is generally much cheaper than the labor to get yours working again. Good Luck
Oct 31, 2009 | Vicence Woven Strap Watch
Got it wet
You have to open the watch, take out the movement, take out the battery, dismantle whole movement and dry it in special watch cleaning machine. Do not hope the moisture is affecting the look of the watch only (misty) - it is definetely affecting movement and battery as well and your watch may stop for good after some time.
My advice - find your nearest watch repair shop and ask to dry it out.
Even if the visible mist inside watch has gone, there are still water in the watch movement.
Rate me, please.
Apr 04, 2009 | Gucci New G Link 110 YA110509 Watch for...
Where is the second battery located on a timex indiglo ?
The second battery is located underneath the top part of watch movement wich consists of two parts screwed or clipped together. Actually it is the bottom, not the top part, as 99% of watches are opened from the caseback side.
Some watches are assembled in the way, that after extracting the big battery, you can reach the second battery through the hole in movement. If this is not a solution in your particular case, then you have to take apart watch movement to reach the second battery.
If movement parts are held together by screws- simply unscrew them. If movement is held together with 'clip-on' steel plate- you have to unclip the plate by pulling all clips outwards from movement.
Allways memorise the polarity of batteries and the correct position of every watch movement part, even screws. This will make reassembly easy and correct. If there are any screws you need to unscrew- do not mix them up as they can be different lengths and sizes. Screw them back in the same holes they came out.
Don't forget to rate, please.
Jan 14, 2009 | Timex Expedition C45981 watch
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
