Question about Panasonic KX-T7431 Corded Phone
Where is the CLEAR Key? - Panasonic KX-T7431 Corded Phone
  • Panasonic Master
  • 2,460 Answers
In an entry, it's the TRANSFER button. You clear a set by PROGRAM 99 # STORE.
Carl
Posted on Aug 20, 2010
Code M4 erro
Service mode, first
1.Press the Utility key.
2. Press the Meter Count key.
3. Press the following keys in this order:
Stop  0  0  Stop  0  1
for security "Stop 9"
In Security, Select Copy Kit
1. Touch "Set."
2. Press the Clear key to clear the current setting.
If the setting is accidentally cleared, press the Interrupt key to
undo the clearing operation.
3. Enter the desired value from the 10-Key Pad.
4. Touch "Current."
5. Press the Clear key to clear the current value.
If the current value is accidentally cleared, press the Interrupt key
to undo the clearing operation.
Jan 15, 2014 | Konica Minolta DiALTA Di200 Copier
DEVELOPER COUNTER CLEAR IN SHARP 5127 \r\n NOT WORK
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
Clear key, Interrupt key , "0" key , Interrupt key , 42, Start key , 1 , Start key
Developing counter clear.
Nov 30, 2010 | Sharp Office Equipment & Supplies
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to clear tabs on a Swintec 8016.
To get to tab clear try the tab set key with the code key or the shift key.
DickyO
Sep 18, 2009 | Swintec 7040 Typewriter
I have a Sharp Z 835 copier that shows an H4 error code.
One of 2 solutions either:
  1. Press clear, zero, zero, clear or
  2. Press clear, auto (exposure key), clear, auto
When pressed in a timely manner the display will go blank, then enter 14, then press the start key. If the H4 comes back there is a problem with the heat section, probably a blown heat lamp or corroded terminals.
Good luck
Bob
May 05, 2009 | Sharp Office Equipment & Supplies
Problems with Toshiba copier
Just press these keys with sequence and with in 2 or 3 seconds .first press clear,then auto photo mode select key,again clear ,auto photo key,.copier will go dead .now press 14 then start key.problem will bi removed.
clear key,auto photo key,clear,auto photo key,
when display dead 14 start key.
BY MIAN JEE
Nov 15, 2008 | Toshiba e-Studio 350 Copier
Clear All Memory Files
exit "store" mode (if it is in it)
clear display
hold down the Code key and hit the C key
message should come up "CLEAR ALL FILES Y/N?"
hit Y, message should say "ARE YOU SURE Y/N?"
press y again to clear all files
to cancel the memory all clear function, press the N key at the first or secound prompt
Nov 13, 2008 | Nakajima AE-740 Typewriter
Wrench and Snowflake
wrench means service problem. "snowflake" I assume you mean the developer symbol. Machien on - depres the clear key then the expose key then the clear key again then the expose key you are now in simualtion mode. depress 20 print 01 print this will turn of the maintenance or wrench code. Depress 24 print 06 print will clear the developer. turn on and off
Apr 09, 2008 | Toshiba e-Studio120 Copier
Copyer
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Sep 04, 2007 | Sharp AL-1641CS Color Copier
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Panasonic KX-T7431 Corded Phone Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
