Question about Grilling
Marshall 290-00. Trailer has a propane hot water heater, furnace, three burner stove and an outside propane outlet for a BBQ. The last two propane tanks were only half empty when the pilot light on the hot water heater quit and would not relight even though several hours had elapsed after the shutdown. All the other appliance still worked fine. I have checked both the regulators as called for in the Marshall Instructions and looked for the vent on the lower regulator - which I could not find. Any ideas as as soon as I go to a full tank everything is fine?
5 Suggested Answers
SOURCE: BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Posted on Jun 13, 2009
  • 34 Answers
SOURCE: uniflame bbq. doesnt get quite hot enough
You probaly need a new regulator.
Posted on Apr 17, 2010
  • 3253 Answers
SOURCE: Motorhome with propane line made for bbq. Bbqs (2
are the burners blocked or the orfice or the gas on /off controls blocked
Posted on May 25, 2010
  • 494 Answers
SOURCE: Propane was leaking between tank and regulator on
I would recommend you take the regulator, hose and 20# cylinder to your local propane co and have them check it out for you. Or if possible, just load the entire bbg in a truck and bring it all to them. Call first to schedule a time that can look at it. If you replaced the tank and the regulator, my guess is that you probably have a cracked fitting or the fitting is missing an integral part that seals it to the tank. Douglas
Posted on Jul 29, 2010
How do I fix the propane oven in a Dutchman travel trailer?
check for a electric solenoid for the fas to the oven or a simple tap for the oven
could be a safety requirement for gas ovens in vans
Sep 17, 2017 | RVs
Tip
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to get the heat from the wood stove to the living space.
If you have a hot water heating system already installed then you obviously need to have a water stove. If you are thinking about what to install in a new home or already have hot air then you need to consider what will be the best option for you.
Now if you are installing a new system then you want to go hot water. That is by far the best way of heating and will be the best way to heat using an outdoor wood stove. Hot water heating is one of the best ways to get great heat transfer from the fire to the water to the air.
If you have hot air heat and want to heat with wood then you can install a wood hot air furnace, and set it beside your existing furnace. The ductwork will have to be reworked to get the heat from the wood furnace to the existing ductwork. Or you can install a coil into the ductwork on the supply side of the furnace, for the water to run through from a hot water wood burner. This is probably the best way to heat if you have a hot air furnace. Installing the hot water coil is a very simple process and the piping is fairly easy to hookup.
Hot air wood furnaces are almost always a inside the structure appliance, which means that you have the mess of the wood and the ashes inside. This dust and dirt mess is something that is much better kept outside where it can be cleaned up much easier.
Bottom line here is that you want to use a hot water wood burning stove if you can. You will be much happier with the heat that you get from burning wood.
on Dec 08, 2009 | Heating & Cooling
Last year we had all the siding on our tv, trailer, replaced due to hail damage. When we finally got our trailer back from the rv repair shop we have had nothing but problems with our Atwood hot water tank...
Immediate danger!
You have a gas leak.
Propane is heavier than air and will settle on the floor.
The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed.
Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside.
Possibly you have a bad gas control valve. This should be repaired professionally.
Aug 08, 2012 | Water Heaters
My gas furnace fires but then cuts out. There is a similar post on here about this but my problem is a little diiferent. The unit kicks on, fires then shuts right down. The blower comes on and stays on....
HAD A similiar problem last week with a customer who had just installed a pool and running off of propane tank for gouse as well... he let tank go empty and started having problems ..what we ended up finding is that not only was his regulator on tank bad he needed a additional regulator to regulate the different psi pressure to the appliances... get them to check your regulator out
Jan 24, 2011 | Goodman Heating & Cooling
I own a 31' trailer which has an ATWOOD G6A-8E RV Water Heater, 6 Gal electronic ignition, 2 yrs ago the pressure relief valve would open up and empty the hot water tank completely, it did this several...
Most electronic ignition models only show the red light if there is a problem, (did not ignite) for one reason or another. To start with, make sure your propane is on, and you have a good flame at stove top burner, just to be sure the water heater is getting propane, and all air is bled from the line, which may cause water heater to go into check. (red light) If it does, shut switch off, and retry. Let me know what happens. As far as pressure relief opening and emptying the water heater, and your sure it's not a faulty pressure relief valve, then there's 2 things to start with checking. 1st, does the water seem extremely hot, thus a possible faulty thermostat &/or ECO . Secondly, if the incoming water pressure is too high, that will also cause it to leak bad. Try installing a pressure regulator (usually 40 psi.) at your hose connection. Let me know what you find.
May 25, 2010 | RTO Atwood Water Heater - 6 Gal LP
My propane furnace sounds like a blowtorch when it kicks on but it also happens to my cooking stove
Hi, working with natural gas and converting them over to propane for the country folk, I do indeed know the sound. You might want to take a look at the burner section for any signs of carbon,soot, build up any where.If the gas pressure has changed for some reason, you will get this blow torch sound.You would need the correct meter to check or measure the inches of W.C. Inlet pressure not to exceed 1/2p.s.I. Outlet for propane has changed over the last 10 years, you will now find on the MGV (main gas valve) for propane is almost the same as with natural gas.W.C. is a measurement used in reading gas pressures, stands for inches of water-column. Recommended pressures are well marked in manuals and on valve its self. Right at 2.5 to 4" w.c. So, check for carbon build up and clean if needed.If it burns radical, pressures should be checked with a gas pressure test kit.Yellow Jacket makes a good one. I hope this has been of some help to you, Sincerely,
Shastalaker7
Nov 17, 2009 | Empire GWT-25 Wall Mounted Panel Heater
COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Feb 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas hot water tank, pilot light
Look inside the water heater when it is heating the water, the flame should be blue. If it has yellow tips on the flame, it needs an adjustment to the air shutter. There is a nut on this air shutter to make this adjustment. This adjusts the air gas mixture. You may first try just simply tapping on the burner lightly to loosen any debris that may have built up and vacuum it out. MAKE SURE YOU TURN OFF THE GAS BEFORE CLEANING THE BURNER!! Also, check for drafts that may be blowing out your pilot light, Furnace register or outside drafts on windy nights. Some water heaters have an automatic shut down if the water heater gets too hot, so don't have it set to its hottest setting. Most water heaters only last about 10 years or so, It could be you are ready for a new one....Joe
Dec 16, 2008 | Water Heaters
Grilling Logo
100 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
