Question about Garden
Weedeater 25cc electolux motor does not have spark
    President:
  • 1,545 Answers
Make sure when you test for spark, you use a spark tester or at least ground the base of the plug to the engine when you use the pull start. A strong little blue spark should be present. The airgap between the coil and the flywheel may need to be adjusted. The specs are about .010-.016" or the thickness of a regular business card. You would have to loosen the two coil screws on the back of the engine's cylinder if you have checked and determined it actually needs adjusting. Covers will be have to removed to get to this location. Torx head screws hold everything on these together.
Posted on Aug 21, 2010
Testimonial: "This tip has pointed me in a sound direction to fix the blower!"
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
No spark on Weed Eater FB25 25cc Gas Blower
Test the kill switch first, disconnect the kill switch and see if you have spark. Then the kill switch is not working or is grounding out. If not, the problem could be the ignition module.
Mar 16, 2013 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
What is the spark plug gap for weed eater 25cc leafblower
Hi Joyce,try 015" thats 15 thousands of an inch.with imperial feeler gauges.Cheers.Ronnie.
Apr 21, 2012 | Weedeater 25cc Gas Blower ()
I have a Poulan WeedEater. It had trouble
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Jan 10, 2018 | Craftsman 25cc Gas Line Trimmer
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
