Please advise me on how to connect my Philips DVD 951 player to my Philips FR 968 Receiver. I cannot make sense of the connections, though I tried to follow the directions from the manual pages of each instrument.
  • 11,800 Answers
The easiest way is to do it fully analogue so you will need 2  cables with RCA connectors:
The first one with yellow (for the Composite video) red (for the Right audio channel) and white (for the Left one). Plug this in the corresponding output connectors from the back of the player (they are close together).  The other end of the cable plug it in the corresponding VCR entry labeled IN/PLAY (vertical arrangement, video connector on top).
The second cable is identical with the first one. From it you will use only the yellow connector - plug it in the TV connector on the receiver and the Composite connector on the tv.
Now all you have to do is to select the VCR source on the receiver and the Composite on the tv.
This setup will give you the image on the tv and the sound on the speakers from the receiver.
Posted on Aug 20, 2010
What do i need and how do i connect my iphone to my phillips FR 968 so i can listen to music??
http://www.manualslib.com/manual/128395/Philips-Fr-968.html?page=11#manual
Looks like you need an audio splitter to Left/Right mini plugs.
Such a cable goes from the earphone output on your iPhone to the CD in plugs on the back.
Alternatively you could purchase a bluetooth converter, plug it into your digital input, and pair it with your iPhone.
Mar 22, 2015 | Philips Fr-968 Digital Audio/video...
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
Had to get new DVD player as old one packed up. Connected one year old Samsung television receiver LA26B450 to new Philips dvd player DVP3560K but gives no colour, only black and white. Have checked...
to put this simply ive spent almost all day advising on this exact problem have alook at my fixes and it will show you the problem but to put it simple you either have connected the wrong cables ie-- rca vs caroma the best way to fix this is to correct the setting in the output on your dvd player it needs to know what signal to send the tv ie rca caroma or hd cable
best of luck let me know if you need further help
sonic boom electronics
Dec 28, 2010 | Samsung SP42P2S Television
How do i install a dvd player with dish network
Hello, if your receiver and tv are HD you want this hooked up separately to get the best picture. If you just want it hooked up to standard definition then take the cable going from the receiver to the tv and connect it from your receiver to your DVD then connect one from your DVD to your tv.
Daniel Busa
DISH Network Customer Service
Dec 23, 2010 | Philips DVP642 DVD Player
HOW TO HOOK MY SONY RECEIVER TO MY PHILIPS TV
Connect the Sony Receiver's HDMI output to HDMI in Philips TV.
You can connect a DVD player or STB to either HDMI In of Receiver or HDMI in of Philips TV.
Jan 02, 2010 | Philips 52 In. LCD HDTV
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
No video in my philips dvd622
Check if you have not accidentlychanged to progressive mode which can cause this proble.
Are you connected to TV using Composite video out?Try connecting using S-Video or DVd (component inputs).
Do provide feedback and rate this solution.
Samir
Mar 26, 2008 | Philips DVD622 DVD Player
94 people viewed this question
 Grubhead
Grubhead
