When i turn it on it tells me to enter pass word after i do that it goes to a phoenix bios set up utility how do i set it up to start normally with out asking for a pass word
I have the similar problem. i haven't solved it yet but do not change the hard drive. there is nothing wtong with the harddrive
Posted on Dec 28, 2011
    Novelist:
    Scholar:
  • 134 Answers
Actually, this sounds a little like you need to replace your bios battery on the motherboard. If the same thing is continually happening, where it asks for a bios password each time the pc starts, then it may be that it's failing to save. The bios battery may be the 'button' type & easy to change, or it might be the type thats soldered in.. Check what motherboard you have & request more help if need be. Rgds,
Posted on May 03, 2008
  • 85 Answers
Ok
go in bios setup.
enter on enter password option
again enter twoise without type any word.
and save and exit
L500 starts in Phoenix Secure Core Tiano Setup. What is this and why doesn't it start in safe mode when I press F8?
Sounds like the bios software. The bios is a configuration utility that basically tells the internal components how to work together. If the bios is all you can get to come up either changes have been made to the bios and your computer doesn't recognize your hard drive or your hard drive has in fact died. Which is most common.
Booting into bios is typically an indication that something has gone out be it the hard drive or ram memory or just something on the motherboard itself.
I would imagine there are a handful of YouTube videos that can guide you through bios and how to use it to diagnose what exactly is wrong or help you find the right settings too get everything running again. Good luck!
Mar 26, 2016 | Toshiba Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
NEC laptop stuck in Phoenix BIOS Setup Utility
While in the BIOS setup utility, go through the tabs/menus looking for BOOT sequence. Configure the laptop to boot from CD-Drive before any other drive. Have the installation CD in drive.Save the changes made to the BIOS configuration, and exit the BIOS. Reboot.
If the installation medium itself does not have a problem, you should be able to boot from it and have the opportunity to install the operating system.
Jan 29, 2014 | NEC Computers & Internet
Laptop model acer aspire1660 when i try to enter the bios 3 times pass fail it say sistem disabled [10140] eror i forgot the pass i removed the batery from the main board but dont work pls can anione...
Generic Phoenix BIOS: vrgw HP/Compaq Phoenix BIOS: iyta FSI Phoenix BIOS (generic): 37198 FSI Phoenix BIOS ('L' model): 9941947 FSI Phoenix BIOS ('P' model): 2187164 FSI Phoenix BIOS ('S' model): 41572 FSI Phoenix BIOS ('X' model): 92876
Try all those passwords thanks
Mar 22, 2011 | Computers & Internet
What is the dafault BIOS password for Acer laptop?
Some BIOS manufacturer put a backdoor password in BIOS which always works irrespective of what password you have set in BIOS. Its a master password which is used for testing and troubleshooting purposes.your bios pass will depend on the motherboard manufacturer i.e(AMI,AWARD or PHOENIX)not by the laptop itself or the name of it..try these few pass listed below;
AMI BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SWAMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
AMI_SWAWARD BIOS Passwords:
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
PHOENIX BIOS Passwords:
BIOS
CMOS
phoenix
PHOENIX
NOTE: All these passwords are case-sensitive and are changed from time to time by manufacturers.
Feb 21, 2011 | Computers & Internet
Acer aspire 2920 bios password removing
The password to by-pass bios password are these, hope they will hope you, once you enter BIOS using these passwords you can reset it to normal
Phoenix Backdoor BIOS Passwords:
  • BIOS
  • CMOS
  • phoenix
  • PHOENIX
Mar 18, 2010 | Acer Aspire 4720 Notebook
What is phoenix. My lap top doesn?t work he says press F2 to enter SETUP. When I press F2 he says enter SETUP. What?s that means.
Phoenix, is the brand of BIOS installed on the system. BIOS = Basic In Out System and is the imbedded software (also known as Firmware) of the motherboard that coordinates the communication of the hardware (Motherboard, drives, video card etc) with the operating system (Windows). The SETUP refers to the parts of the BIOS that can be configured by the user. (You can turn components on or off, and change various settings or see what componets are installed in the system.)
http://en.wikipedia.org/wiki/BIOS
Oct 06, 2009 | Computers & Internet
Phoenix bios password
The thing is that somebody set bios password. On phoenix bios based on intel platform? like yours normally if you will enter bios password incorrectly 3 times bios will lock the computer and it will generate 12 digit lock code. You will need to contact Toshiba technical support to get bios unlock password. (Normally this is generated by them within couple of hours.)
I would recommend you to check with toshiba support before locking bios (entering password incorrectly 3 times)
May 28, 2009 | HP Pavilion dv1000 Notebook
May be a bios problem
Sounds like it is a hard disk issue. Corrupted MBR. Or missing Boot Loader. Your partition must be Fat32 since Win98 won't recognize NTFS. Try running chkdsk if not successful than repartition and format. BIOS is OK since you stated it will install windows. Corrupted BIOS won't allow pc to load. From a win98 bootdisk choose not to load cd. From the dos prompt type FDISK /Status If more than 1 partition check active partition settings.
Nov 05, 2008 | Intel Motherboard
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
