Question about Belkin (F5D7633UK4A) Wireless Router
My router stopped working and the security light is flashing
    Sergeant:
    Champion:
  • 310 Answers
I would suggest you reset the router once. To reset the router , please follow the instructions in the link below.
http://en-us-support.belkin.com/app/answers/detail/a_id/48
If the router doesnt respond, then time to get a replacement. Please call Belkin Support and am sure they can help
Thanks Ranjit
Posted on Aug 20, 2010
Orange light on the router
The color orange indicates that
the Router is not using the SecureEasySetup
feature, while the color white indicates that the
Router is using the SecureEasySetup feature.
When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and
start flashing. After the Router has generated
the SSID and WPA Shared Key, the Cisco
logo will stop flashing and stay white.
So this "feature" can be turned off (meaning the light is off)
On the web-based router setup (192.168.1.1 in web browser) go to Wireless > Advanced Wireless Settings
Secure Easy Setup
This feature allows you to enable or
disable the SecureEasySetup feature. Select Disable to
disable the feature and turn off the button's light. The
feature is enabled by default.
Click the Save Settings button to apply your changes, or
click the Cancel Changes button to cancel your changes.
Dec 11, 2012 | Linksys WRT320N Wireless Router
We have been using the Netgear router WPN824 for about 3 years and all of a sudden it stopped working. No flashing strobe lights - nothing. any suggestions?
Will it even power on at all ? If there are no lights at all make sure its plugged in securely. Maybe even try a different power outlet to see if the one you are using has not gone bad. If that still doesn't help then there is a chance that your router has failed. Being 3 years old it is possible. A failure can be from a power surge, storm, manufacture defect etc. In which case you will have to replace it. Sorry for the bad news.
Thank you for choosing Fixya,
Daniel
Jun 26, 2011 | NetGear RangeMax WPN824 Router
My security indidcator light is flashing every 2 seconds when my car is shut off. It stops flashing once I turn the vehicle on. How can I get it to stop flashing when the vehicle is off?
The security flashing is an indicator that your security system is armed and working.
It helps deter thiefs when they see the flashing light. They know if they try and break in your car the alarms will go off.
It is a good thing the red light is flashing.
Hope this helps ease your mind.
Wayne
Nov 11, 2010 | 2006 Mazda 6
I need the security code for my Wireless-G Broadband Router Model No. WRT54G
The security code can be reset to factor defualt by pressing and holding the rest button for 5 seconds on the back of the router and waiting for the lights to stop flashing. password will reset to Admin.
Oct 24, 2010 | Linksys Wireless-G Broadband Router
My router has stopped working this morning. The modem router light flashes blue a couple of times then the security light and modem router light up blue for a couple of seconds the all turn off. None of...
TRY RESETTING THE ROUTER. THERE WILL BE A SMALL HOLE IN THE ROUTER WHERE THE RESET BUTTON IS. INSERT TOOTHPICK OR SOMETHING NON-METALLIC AND DEPRESS FOR 30 SECONDS. THAT SHOULD RESET IT.
GOOD LUCK
Oct 19, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My internet light on my router wont stop flashing
If the internet is working, then this is likely normal behaviour for your router and there is no problem. If so, cover the led's with black electric tape if it bothers you. :) (I've done this on my dsl modem)
If the web is not working, maybe reset the router by holding down the reset button for 30 seconds. If still no good, contact Belkin as the router may be dead. If a reset works, make sure to secure the router with a strong password if it's wireless.
Aug 17, 2009 | Computers & Internet
Security light flashing and ignition doesnt work
your ignition switch is bad for now though turn your key on for at least ten minutes until the light stops flashing this will reset your security system after stops flashing turn key off and then start the truck
Mar 17, 2009 | 1999 Chevrolet S-10 Pickup
Flashing Lights
The flashing lights meen there is a configureation problem with your snapgear. Check your settings to make sure thay are current for your new location. Just because you own an IP/DNS from one service does not mean that it will be valid from another service. Some services use a system where you set your router to DHCP and they assign you your static IP/DNS. Also Snapgear routers have configurable ports so they are going to be picky about what is plugged into what port. Hope this helps
Jun 26, 2008 | SnapGear SME 550 (990065) Firewall
Belkin Wireless won't work at all - it won't even flash
Is this a brand new router? If so, did you use the Setup Assistant Software that came on a CD that was included with the router? This should have taken you through all of the necessary steps to ensure that wireless was working.
When you say that you "reset the router", did you just push the RESET button or did you hold it down for 10 seconds to restore the Factory Default Settings?
If you have the CD, I would recommend that you hold the reset button down for 10 seconds and go through the set-up process. If you do not have the CD, you can download the software here:
http://tinyurl.com/6ra889
I recommend that you set up a basic wireless network and the add security once your router and wireless computer are communicating. For this to happen, you just need the two devices to match on the SSID.
If you need the manual, you can download it here:
http://tinyurl.com/6heo43
By the way, the blinking green wireless light just means that the router is detecting wireless activity, and this can be from other computers in your vicinity.
May 31, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7633UK4A) Wireless Router Logo
65 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
