Question about Amana ARB1914C Bottom Freezer Refrigerator
Water dripping inside frig compartment - Amana ARB1914C Bottom Freezer Refrigerator
  • Amana Master
  • 43,501 Answers
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Water pools at the bottom on the inside the freezer side of a side by side frigidaire. This frig has a water line for automated ice and dispenses water/ice on the outside. At the bottom there is a vent...
your defrost drain is plugged remove the back panel in side the freezer at the bottom you will see a metal pan with a hole in it clean around the whole and flush it with hot water a turkey baster works great for forcing hot water thru the drain and clearing what ever is plugging it
Mar 07, 2010 | Refrigerators
Frig has water dripping from freezer door
the coils are frozen up from condensation due to leaky door seals and/or a plugged drain. turn it off, defrost it with a hair dryer, check the seals and the drain (under the coils), and turn it back on.
Nov 12, 2009 | GE Refrigerators
My Whirlpool Refrigerator Model ER8MHMXML02 isn't as cold. Help!
Freezer drain plugged and froze up also froze the air returns to frig
Aug 22, 2009 | Whirlpool Refrigerators
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water
Look at your door gaskets. If they ain't kosher then excessive humidity will build into the frig.
Jan 02, 2009 | Frigidaire GLRT188WD Top Freezer...
Water from the freezer falling in fridge
Usually this is a Door seal problem or a blockage between the frig and freezer compartment. There is usually a Tube that allows water from the defrost cycle to drain down to the pan beneath your unit. If there is ice, food particles, etc blocking that will cause water to enter the frig causing the mess. Listen for a fan to be running inside the freezer....if you hear none, than this may be causing the ice buildup that melts when the unit goes into defrost. If you unplug the unit, take the back panel off inside your freezer you will see coils and the ice. Leave unit unplugged to defrost the freezer and drain tube.....It should work normally when you plug it back in. If not, then you have a defrost heater or thermostat, or control board problem that needs to be checked by a technician.
Nov 29, 2008 | Whirlpool Refrigerators
Amana ARB1914C Bottom Freezer Refrigerator Logo
53 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
