Question about Cameras
My sanyo x1250 is saying system error when i turn it on
My camera is doing the same thing. Of course, my warranty just ran out. The user reviews on this camera are not hopeful
Posted on Sep 13, 2010
3 Suggested Answers
ashlocked
  • 1140 Answers
SOURCE: What does it mean when
try to reset your cammera settings to default
try to change memory card first.
try to format your memory card
Posted on Jun 05, 2011
t00nz
  • 4738 Answers
SOURCE: I have the Sanyo x1250 and it dropped with the len
Lens errors (system errors on Sanyo's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Posted on Oct 17, 2011
Cant turn on image stabilizer
When you are in recording menu, third line in the menu says Photo Stabilizer. But if tat one is grated out, that means it is not available. The manual never says anything about the stabiliser function.
So if your camera allows you to stitch between stabiliser on or off, please let me know.
Jan 02, 2014 | Sanyo VPC-X1250 Digital Camera
I have the Sanyo x1250 and it dropped with the len extended. When I turn it on, the lens goes partcially in and out while making a clicking noise, and after a few seconds of this, it says system error on...
Oct 17, 2011 | Sanyo VPC-X1250 Digital Camera
What does it mean when your Sanyo VPC-X1250 digital camera says "System error?"
Jun 05, 2011 | Sanyo VPC-X1250 Digital Camera
I have a Sanyo digital camera, model: VPC-X1250; it now takes blurry pictures where you can't tell what the subject is even when i am inches away from the person's face. it also turns on, makes a...
hi According to your information, somehow your camera has lens unit defective. Your local repair shop would charge around $ 35 to 75 depend on what really want to charge. Thanks and best regard!
May 24, 2011 | Sanyo VPC-X1250 Digital Camera
I Dropped my Camera and Now the Lenses are Not working Properly and it keeps saying "System Error"
Lens Errors (a.k.a. "Zoom" and "System" errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try.
May 12, 2011 | Sanyo VPC-X1250 Digital Camera
My lens is stuck and it turns on but it says sysyem error how can i fix it
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 27, 2010 | Sanyo VPC-X1250 Digital Camera
I lost my charger for my Sanyo x1250 digital camera. Cant i use my USB cable as an alternative charger?
Did the mains charger connect to the camera's USB port? If so, it will probably charge from any USB port including your computer. Otherwise, no.
I found a charger (and batteries) for this camera on Amazon by searching for "Sanyo x1250 charger".
Nov 30, 2010 | Cameras
My Sanyo X1250 Digital Camera says System Error evertime I turn it on. Is there anyway I can fix this without returning it??
this is how I got mine to work, while off hit the play button the triange icon on back of camera. go to reset under the wrench icon, set the date and time and sgut it off. turn back on. fixed!!!!!!!!!!!!
Oct 18, 2010 | Sanyo Cameras
System error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 06, 2009 | Sanyo Xacti S650 Digital Camera
Cameras Logo
168 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
