Question about Ovens
Find the error, its impossible 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 80% of UCDS students could not find the error above
The error is that 80% of people that could not find the solution that is 'impossible' to find means that 20% did, which of course is impossible; there is no solution to an error that is impossible to find.
It's a bit of a lame riddle really and disappointing when worked out.
Posted on Oct 22, 2010
F2 error on EOC68000 oven
Not exacltly the same oven but I got F2 error and solve it by :
1) Find error code on : http://appliancehelponline.com/whirlpool.html
2) take out the temperature sensor
3) the oven now indicates F1 error
4) measure sensor with ohm meter : should be a bit above 1080 ohms
5) clean the sensor carefully
6) put it back in the oven
fixed !
There is also a little circuit breaker with a red button in the oven. I also push it (maybe a reset?)
Mar 09, 2013 | Ovens
My JPK27W0W1WW is reading error F7. What does that mean?
Normally this means the clock or ERC can not see the touch panel. Usual its the cancel button that stuck and confuses the clock. You will have to verify the problem, I would shut the power down, remove the panel, disconnect the ribbon to the clock, turn the power back on, and see if the clock still faults out. If it does, than the clock is the problem not the touch panel.
Without verifying its impossible to determine which of the components failed.
I hope this helps..
Jul 23, 2011 | GE Ovens
What is F10 error code
http://www.applianceblog.com/mainforums/sears-kenmore/11065-kenmore-range-f10-error.html
Hi this website above directly addresses your issue.
F10, is an Over temperature, usually a bad thermistor or similar, as related see above post. For ID & repair parts and all.
Nov 01, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
How do i fix error code F04 on Zanussi ZPB1260 single oven
Error Code F04 is due to the mismatch between the incoming line voltage and the voltage setting of the oven. To correct the error code follow the instructions given below : a) Make sure the line voltage corresponds with the setting of the oven. The voltage selector is located at the back and consists of two plugs. The white plug sets the oven for 208 V and black plug (or white plug with a black dot) sets the oven for 230 V. b) Make sure the line voltage is within +/- 10% tolerance. This is especially important during summer months, where line voltage has tendency to drop. c) If both steps above check OK, the error(s) may be caused by defective controller (DPU) board.
Jan 20, 2010 | Ovens
How do you recover a lost ms office 2007 student product key? I really bought it, but the key , which was sent to my student email address, was lost when my university changed its email system to ms...
If you have the product reinstalled (not a clean install from a disc) just go to the Microsoft Office Word program and look for the Microsoft Office button.
Click the Microsoft Office button at file menu. In the drop down menu, click WORD OPTIONS, down on the very bottom of the menu.
Go to resources and about selections and you will find your key and how to activate online. Pic below.
To left is is the activate product option. Highlight that. Or, if the program is not installed and you only have the activation assistant, use that.
Look for the trial version ICON on your desktop and click the link that says display activation code.Use the support buttons and phone numbers provided to retrieve the proper full license number if the keyis not displayed.
There are also free keyfinder programs and a few other ways to display the number. But, if you did a total, clean installation you may have to contact Microsoft support to get your product code. There is 90 day free support for Office trial conversion, may be they will have mercy.
Reinstallations often leave critical info on the hard drive, so it is worth a shot using magical jelly bean finder if all else fails. Thanks for your problem, and good luck.
Dec 14, 2009 | Ovens
Oven Temperature rises above setting
You may or may not see the error code.
The temp probe is less expensive and is most likely your problem.
If you choose to replace it and the problem remians your ERC will have to be replaced.
ERC electronic range control
Mar 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
Jan 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Belling 592SS self clean panels need replacing
Go to:
www.belling.co uk and follow the links
You should find what you are looking for
Dec 08, 2008 | Belling XOU592 / XOU593 Electric Double...
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
Ovens Logo
493 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
