Question about Electrolux E23CS75DSS Stainless Steel
I have a EI23CS55GS1 Electrolux Fridge and I have just replaced the water and air filter for the first time. I followed the instructions of holding down the air filter and water filter buttons for 3 seconds to see if the replace light goes off and the good light come back on in green. The good green lights up for a second but then disappears and the red replacement light continues to stay on. I was told by Electrolux to shut off the fridge from the breaker but this hasn't made a difference at all. HELP!
SOURCE: Fridge prolems Electrolux ERE 3500
No it is a power problem.
Posted on Jun 24, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 29, 2009
  • 400 Answers
SOURCE: electrolux RM212F caravan fridge manual ?
Try this link: http://www.club80-90.co.uk/pages/downloads/tech/RM212Elect.pdf
Posted on Nov 05, 2009
  • 37 Answers
SOURCE: electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Posted on Jan 09, 2010
SOURCE: Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Posted on Apr 12, 2010
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
I have an Electrolux refrigerator (ei23cs55gs1) who's display is stuck on "door ajar" and does not let me select ice to dispense only water. The display is not complete (like a series of dashes) but turns...
you could have a defective switch or a defective display. Check as best you can to see if the switch is being depressed by the door when its closed. Check to see if it works, hold the door open and depress the switch yourself and see if the light goes out. If the light stays on you need a new switch. if the switches seems to work ok you make need a new display board.
http://parts.sears.com/partsdirect/part-model/Electrolux-Parts/Refrigerator-Parts/Model-EI23CS55GS1/1412/0165000/R1201135/00007?shdMod=EI23CS55GS1
Aug 05, 2013 | Electrolux Refrigerators
Electrolux Pure advantage water filter
Open and shut the water valve quickly to verify the water supply, it could be a bad water supply valve. Bench test the filters for flow or obstruction.
Aug 01, 2017 | Electrolux Icon Freezers
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
I have an electrolux sisde by side with an in door water maker (model EI23CS55GS1). Its about 1.5 yrs old and the water dispenser in the abruptly stopped 2 days ago. The Ice machine is still working just...
More than likely the microswitch for the water lever has failed or broken.
You'll need to access the dual water valve on the back of the unit to determine that when you press the lever - the solonoid on the valve is getting voltage.
If it is getting the turn on voltage - the solenoid is bad and needs replacing.
If it is not getting a signal voltage - the switch is bad.
CLICK HERE for all the diagrams to your unit.
Unfortunately - most parts on this unit are unavailable. I have checked 3-4 different vendors.
This unit also uses a electronic board controller instead of individual components that can be easily replaced.
The replacement module for this unit is $376 and can be seen HERE as part #38C.
The dispenser module (#8) is not available.
Contacting the Manufacturer may be your best bet in finding replacement parts or an authorized repair center that can access the parts.
CLICK HERE for their service locator.
Thanks for using FixYa!
Jan 02, 2010 | Electrolux Refrigerators
New water filter replaced follower instructions in book Orang lig
There is no sensor that knows you replaced it. Probably have to hold down a button or two to reset light on dispenser area; read your manual for directions or find it on-line from the mfr website if you don't have it. I do not know what key sequence.
Nov 27, 2008 | Refrigerators
Jenn-Air "replace filter" light
each dispensor is a little different, but youll need to hold down a button(perhaps even a combonation of 2) for3 seconds to "reset " the filter indicator.
Mar 19, 2008 | Jenn-Air JSD2789GEW Side by Side...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Electrolux E23CS75DSS Stainless Steel Logo
184 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
