Question about Linksys WRT160N Wireless Router
When i try to change my wireless security setting for network i get this error msg.error msg. msg100_000_000 unhandled error, please see Lela log for more info.
  • 4,924 Answers
I never heard about this message again ..but rather than struggle with it ..and go nowhere ..just reset the router to the factory defaults ..by pressing the reset button (it is a hidden in a hole on the back near the power supply and accessible with a pin or a ballpoint pen ) ...Be sure the router is on and powered when you press that button for 20 sec..
Do this just in case you know how to set it again ..cause you will have to take it from scratch ..and make the wlan connection again ..and after that to set the wifi and the security for it ..
Posted on Aug 21, 2010
Have problem going online, after inputting all info the first time it logged on fine and a atomatice update took place. But after that, the next time i switched on and the ps3 try to log online , a error...
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Router's wireless function not working
please visit my profile bro. coz i posted there some tips about routers configuration and internet connection errors. here's the URL: http://fixya.com/users/chael890
May 31, 2010 | Computers & Internet
SECURITY
log in to the router setup page.... you can type 192.168.2.1 in IE to open the setup page...on the left side you ll find an option called security below wireless heading...click on that and change the security mode to 64bit WEP....in the key1 you need to enter a 10-digit number (5pairs)as the security key for your wireless network...donot enter anything in any other boxes....click on apply changes....now close the IE...go to network connections and delete all preferred networks from your computer....now scan and connect again....it ll ask for a password...enter the security key and get connected....
Mar 23, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have tried to install Easy link advisor and i keep getting an error message. (MSG-100-000-000 Unhandled error see Lela) but i cannot get to the help menu. Any thing that I am doing wrong? Thank You,Karl
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 17, 2010 | Linksys WRT160N Wireless Router
I have a linksys router model #wrt1601 I'm trying
LELA is a software to help you set up router. But that software has lot of issues. It will be better if you uninstall that software and change the settings of your router manually.
it is very easy to change the settings manually.
Click Here for More information
Oct 07, 2009 | Linksys WRT160N Wireless Router
Cant connect to secured wireless network...
Hi Grant,
If it says aquiring acquiring network connection while you connect to the wireless network it means that something is conflicting with the wirelss network, so first you have to check wether 2 wireless utiliies ( windows wireless utility and dell utility )are active at the same moment, if yes disable one of them and try again, still if it does not connect, disable antivirus and firewall and check if that fixes the issue, still if it does not work then try changing the security type on the routers page, basically this should work out and still if u have any issue, please reply to this msg for further troubleshooting steps....
And even if it gets resolved please reply once.
Thanks and Regards
Anup
Apr 01, 2009 | Dell Wireless 2350 Router
Exception from HRESULT: 0x88980406
There are known issues with the Linksys EasyLink Advisor (LELA). It is a very buggy piece of software that ends up causing a conflict with windows manager as indicated by your specific 0x error code. It is supposed to take the hassle out of setting up your wireless network using Linksys devices, but as you can see this isn't always the case.
The best thing to do, if you are technically inclined, is to uninstall LELA and manually configure your wireless network or hire a teenaged geek to do it for you. If you cannot do this, then try the following (no guarantees):
1. Download the latest version of LELA at http://update.linksys.com/lela/install/lela.exe and save it to your desktop.
2. If you're using XP then go to Start >> Control Panel, click on "Add/Remove Programs", find "Liknsys EasyLink Advisor" and uninstall it. If using Vista, go to Start >> Control Panel, click on "Programs", click on "Programs and Features", find "Linksys EasyLink Advisor" and uninstall it.
3. Reboot your computer.
4. Reinstall LELA by clicking on the LELA file you downloaded in step 1.
Mar 16, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless Adapter can't access internet
I have same problem with WRT54GS router and WPC54G Notebook Adapter. These worked fine until recently...I suspect something to do with installing XP updates and needing new drivers. I tried everything suggested...even updated LELA to newest version, but no success. After hours of frustration, I was ready to chuck it and head to Best Buy to get something different. But I tried one last solution suggested somewhere and it worked for me. Here it is in a nutshell: Uninstall LELA on all computers...sure it's got nice graphics and features, but who cares if it doesn't work!!! Then plug adapter into notebook and let it find the new hardware on it's own. (Linksys is very adamant about running their CD first, but don't do it! You can run the hardware with Windows just fine without LELA.) When the hardware install wizard asks, then put in the Linksys CD so it can download the drivers only. Then set up the wireless network in your network connections and change any necessary router settings directly by accessing it via 192.168.1.1. Yes, I would love to have LELA up and functioning and feel like I have somewhat given up, but when software creates more problems than solutions, I've gotta cut bait. My network now works great. I put a Network Connections shortcut on my desktop to monitor things myself. It's simple and life is good. From these forums, it is obvious that LELA has some real issues. Too bad Linksys hasn't provided a better software product, considering the huge amount of time and money their customers have invested in trying to get it to work!!
Jan 31, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Problem with applying profile
This is typical of your profile (The saved wireless settings on your computer for your wireless network) not amtching the settings on the router. Most commenly this occures if there is a change in the sercurity settings (such as WEP encrytion changed from 64 to 128 bit). If you have WEP or WPA incrytion applied please verify that all your computer has the same settings and key in the wireless profile.
If you have no security set up and your network is Open then is very possible someone logged onto your network and changed your routers security settings (very simple if you left your router's admin password at the default). Your best bet in that case would be to follow the directions in your router's manual to reset all settings to the factory default. After your do be sure to go back through the setup and apply at least 64 bit WEP incryption
Feb 09, 2008 | NetGear WGR614 Wireless Router
Linksys WRT160N Wireless Router  Logo
105 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
