"Windows explorer has stopped working", "Windows explorer is restarting" loop
My computer, when turning it on, presents these messages in a continuous loop. I have tried restoring my computer to a few days ago and ran a virus check however these did not work. Please help!
Duggie.
  • maaz123 May 24, 2008
    i am also facing the same problem.. none of ur solution worked at all!
    Guru:
  • 1,342 Answers
This is another Vista flaw. Click HERE for several solutions.
Posted on May 03, 2008
I am continuing to recieve Windows update error 9C48 and I am unable to fix error
http://www.microsoft.com/download/en/details.aspx?id=23332
Instructions:
  1. Uninstall IE9, if you already have it installed, and restart the computer.
  2. Download the installer.
  3. Disconnect from the internet. This is important because the installer attempts to download the latest, bad binaries from Windows Update.
  4. Let the install finish, and restart.
  5. Reconnect to the internet and check Windows Update. If all went well, you should be able to see the Cumulative Update for IE9, instead of IE9 itself.
Thanks
Mar 13, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
Windows explorer (windows 7) keeps on stopped working and restarting every second
Windows 7 Restarting maybe because of serious computer errors. If you see a blue screen error message for a few seconds before the computer restarts then this is likely to be the cause then it might be a hardware error.
Jun 07, 2011 | Computers & Internet
THERE'S GOT TO BE A SOLUTION TO MY LAPTOP PROBLEM,I KEEP GETTING THIS MESSAGE, "THE COMPUTER RESTARTED UNEXPECTEDLY OR AN UNEXPECTED ERROR. WINDOWS INSTALLATION CANNOT PROCEED TO INSTALL WINDOWS,...
The problem is caused by a damaged Windows installation CD.
There are some files that cannot be read from CD, so Windows gets stuck.
It tries to restart to continue with installation, and keeps doing this on an endless loop.
Solution:
Get a goos Windows Installation CD and start from scratch, (format and load the new copy of Windows)
Don't forget to rate this answer if it helps.
Jan 27, 2011 | Everex StepNote VA4300M Notebook PC
I have a cpu with windows xp and it wont go past the splashscreen
Please try the following:
1.
  • Click the start button
  • Right-click "My Computer" and select "Explore"
  • Right-click the disk (your primary hard disk, most probably should be the "C" drive) and select "Properties"
  • In the properties dialog click the tab "Tools"
  • Click "check now"
  • The "checking disk" dialog appears, check both options and click start
  • You will probably see a message that chkdsk wants exclusive access to the disk and therefore wants to begin first thing after you restart your computer. Accept by clicking ok.
  • Restart your computer
When your computer restarts you will see chkdsk advancing through several different stages of verification, examining your hard disk. If it detects no errors, Windows will continue to start to your normal desktop. If there are errors, chkdsk presents a report with what it has done and waits for your confirmation.
2. If the above doesn't solve your problem, repair the windows xp by doing as is given on the page at http://www.theeldergeek.com/repairing_windows_xp.htm (please see instructions under section "Windows Installation CD - Repair Current Installation:")
Dec 30, 2009 | Acer Aspire E500 PC Desktop
I'm repairing my windows XP SP2 by Windows CD then it go to the "setup is being restarted" loop many people meet (google to see that). Then I know that I must use Shift+F10 to enter command prompt when the...
when it installs components and reboots after format,
it will ask if you want it to boot from CD?
ignore this message!!!
and let it boot from hard drive, (it has already compied files needed there) then the installation will continue successfully
Apr 11, 2009 | Microsoft Windows XP Professional SP2
Internet explorer stopped working
Do you get an error message which asks you send or dont send? if yes, delete all the temporary files by clicking on tools menu -> internet options -> general tab -> click delete button -> click delete all.
If there is no message before internet restarts, then uninstall internet explorer 7 from 'add/remove programs and try in ie6. if that does not work then remove ie6 from 'add/remove windows components' and restart computer then check internet explorer in 'add/remove windows components' and restart again. It should work.
Dec 12, 2008 | Microsoft Internet Explorer 7
Windows Explorer Has Stopped Working???
Hi, when did this symptoms start on your PC? after a windows system update?
Try to remove your present explorer with its previous version... try a rollback of the system to a time before you had this problem. Did it help? Leave me some feedback. Good luck and bye.
Sep 10, 2008 | Computers & Internet
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
