Question about Vizio L32 32 in. LCD HDTV
My vizio tv VP 322 will not turn on ...My question is , is there a reset button.
  • 11,361 Answers
Unplug it for about an hour to let it reset itself. If it still doe not work, you will have to look inside and troubleshoot it.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 21, 2010
Can I fix my vizio e472vle? Or do I need to purchase a new tv? Any Idea what i would need to repair the problems listed below (flciker of menu and smart functions).
Follow these steps to reset your TV:
  1. Unplug power to your router.
  2. Perform a Clear Memory or Reset to Default on the TV.
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
  1. Plug power back to router.
  2. Perform the setup process and reconnect to your network.
Jun 02, 2017 | Vizio Televison & Video
Is there a reset button on a vizio lcd 32 in flat screen tv and where would the fuse be located what happen was my husband accidentally touched the usb where it says sevice with a wire and the tv just...
Hi Kaycee.
I suggest you try to reset the power to the TV:
Start off by turning the TV off and unplugging it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
Hopefully this will get it working for you.
If this does not solve the problem, you can go to the online video, "How to Power Cycle a VIZIO TV" - see attached video.
Reference is
https://answers.vizio.com/hc/en-us/articles/200132879-How-to-Power-Cycle-a-VIZIO-TV
Hope this all helps you
Mar 04, 2015 | Vizio Televison & Video
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
Is there a reset button? My son tried to plug the computer into our Vizio tv and now there is no power - it doesn't come on. I think he inserted something into the "service" plug.
We have a 42" LCD, model E421VA that had a problem. I called Vizio and they told me how to reset the TV. Unplug the TV from the power source, press and hold the TV power button (located on the TV) in for 30 seconds, then plug the TV back in and turn it on. Good Luck
Sep 04, 2010 | Vizio Televison & Video
My vizio wont turn on but the vizio organge light comes on please help
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you.
Mar 26, 2010 | Vizio L32 32 in. LCD HDTV
How to repair Vizio VP 322 power supply
Power Supply repair is NOT easy, but here goes. First Without Power do as"Dry" Multimeter Ohms, check of ALL discrete components looking for "Shorts" Check, Diodes, Caps, Resistors. Coils etc.., Check all Transistors, B.C.E. with your meter set on "Diode test" look for "Bad" junctions. Then you check to see if you have power to and on the "other side" of the Bridge Rectifiers/Diodes. if not, replace that. if yes, proceed. Check for the correct Voltages around the Controller Chip. and Check the output of the Chopper Transformer, Check to see if the Waveform around the Controller IC is right. Check ALL voltages are correct & within range.. Now during this you should have found the faulty Bit(s). Replace as necessary. BE CAREFUL. I always work on ANYTHING connected to mains through an Isolation Transformer.
Feb 03, 2010 | Vizio L37 Television
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Remote code for Goldstar VC681M to match Vizio VP-50 remote
Try 747; it's supposed to work on most combomodels
Feb 18, 2008 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
274 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
