Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
My Whirlpool Duet Sport washer with model #WFW8300SW04 has a bad control board located on the top right side. What is the actual name and part number of that control board?
  • 4,323 Answers
Hi
The part number for User Interface(part# 3 in image) is PS992556 and part# for Electronic Control (part#6 in image) unit is PS2362897. Please check the image for details--
Hope this helps....
Daniel
Posted on Aug 20, 2010
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet sport wfw8300sw04
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
- Check connections of the CCU board within the housing.
- Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Nov 04, 2013 | Whirlpool WFW8300SW
How do i run a diagnostic on a Whirlpool Duet Sport WFW8300SW04 frontload washer
what code is it giving. there should be a paper under front bottom kick panel. that has all codes and sequences on it . or you can google code list . i think it was power button 3-5 sec then any cycle button 3-5 seconds 3 times
Mar 04, 2013 | Whirlpool WFW8300SW
Hi, I have model wfw8300sw04. I'm having trouble with it spining & draining. It won't drain and it spins once and stops. I have check the drain for any clogs and nothing.
Open the door and push the bottom front of the boot aside and look to see if an article of clothing as gotten in there. Post back your findings.
Nov 13, 2012 | Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
We have a whirlpool duet sport washer, the machine is powered on as evidenced by the lit up control panel's LED but when we try to run a cycle, the machine refuses to start and after a couple minutes it...
do you hear the door lock assymbley locking if not then either you have a bad control upper board central control unit uper grey board located top back of washer ........or bad door lock assy
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an F35 code on the front panel
Thanks. Ok, the only part that is of importance will be the actual analog pressure sensor switch. You will only need to replace this part. This part fails in most duet sport(Steamers) models of this nature. It is mounted just next to the Electronic board that is located and mounted on the inside of the washer cabinet. The drum must be removed to access it and the top/front panel, as well. I will post the links to the diagram and part number for the part, below. The actual part that will need to be replace will be labeled number 20 on the diagram provided below.
Exploded Diagram
Analog pressure sensor switch part number -W10156252
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer
F11 is a serial communications error. This is a symptom of an electronic control board starting to go bad. As defined by the technical information provided by Whirlpool, the error could also be caused by a loose or broken wire connector and/or the central control unit (CCU) (front panel). I would double check all your wire connections leading to the control board and CCU, first. Don't be surprised, however, if the problem persists and you eventually have to replace the electronic control board. To check, follow these steps: 1. Unplug washer. 2. Remove the three screws along the top of the washer in the rear that holds the top panel on. 3. Once the screws are removed the top should slide back then lift up. 4. The electronic control board is gray (or white) in color and located in the rear of the washer. It's impossible to miss. Double check all the connections ONE AT A TIME. 5. Double check the wire harness connections leading to the front panel as well. I hope this resolves your problem, but experience has proven that this is usually an Electronic Control Board failure. It could actually be a combination of the CCU as well. The part numbers are as follows: Electronic Control Board: 959503 Central Control Unit: 1025824 Both boards cost about $150 each. Let me know if this helps you.
Sep 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
577 people viewed this question
Dan Webster
Dan Webster
Sal De
