Question about Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How do I switch my TV from analog to digital? And how do I find what digital frequency my cable box operates on?
  • Sharp Master
  • 11,800 Answers
If you have a cable box then you don't do the switch in the tv, you do it in the box. If the box isn't a digital model then you must replace it.
BTW the digital channels operate on the same frequencies as the normal ones, to find them just do a channel scan.
Posted on Aug 20, 2010
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Analog to digital
If this is an older standard tv it is analog only it's not capable of processing digital tv transmissions in any way by itself you will need a digital tv converter box. thats true for antenna reception or cable systems that supply a digital signal,with digital cable systems you will probably need their digital converter box over the air & digital cable converters are not compatable with each other.
Apr 11, 2014 | Televison & Video
What is a converter box for tv
A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set. It may refer to over-the-air broadcast television signals received by an television antenna, or to cable TV systems which switched to digital cable. It normally does not refer to satellite TV, which has always required a set-top box either to operate the big satellite dish, or to be the integrated receiver/decoder (IRD) in the case of direct-broadcast satellites (DBS).
In North America, these ATSC tuner boxes convert from ATSC to NTSC, while in most of Europe and other places such as Australia, they convert from Digital Video Broadcasting (DVB) to PAL. Because the DTV transition did nothing to reduce the number of broadcast television system standards (and in fact further balkanized it), and due to varying frequency allocations and bandplans, there are many other combinations specific to other countries.
Feb 21, 2013 | Polaroid FLM-3232 Television
Do i need to have the bose system turned on in order to watch tv or can i have the cable box bypass the bose receiver? I do not wish to use my bose for everyday tv. Thanks
If your TV has its own speakers you don't need to have the Bose turned on for Lo-Fi watching. Not knowing what your TV has for analog and digital inputs or your Cable Box has for analog and digital outputs...
The LS V20 has 3 analog inputs plus a Tape Loop, so you could have the Cable Box (not the TV) audio; and two (or three using the Tape Loop) other analog sources. NOTHING should need to route to the TV first. The Bose should get the audio from whatever you're watching directly from that source.
If the Cable Box has only one analog audio output available but the TV has a digital one
Since an analog audio output can be split you could 'share' the cable box audio with both the TV and the Bose. Digital audio may also be possible between the Box and the TV.
Jan 10, 2011 | Bose Lifestyle V20 System - black Theater...
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
How do i tune in my digital cable on my analog tv?
You'll need a digital cable box for that, I'm afraid. The analog tuner in the set isn't compatible with the digital cable signal. The cable company in my city just dropped their analog service. Now you either need a digital converter box, or a "cable box lite" called a digital transport adapter. For digital off-the-air broadcasting you need a digital tuner and probably an amplified or outdoor antenna. The analog TV is rapidly becoming pretty useless except as a display device as analog channels disappear.
Mar 11, 2010 | Curtis-Mathis CM19011 TV
My tv is attached to a cable inpt but no cable box i am able to watch all cable channels by switching tv chanels,is the inpt digital or analog
The signal you are viewing is an analog signal.
The cable companies take the signals for your basic channels and resend them through the cable as analog so the customers that still plug the cable direct to their TV can still get some programming without the added costs of digital cable boxes on every TV.
This option will be slowly phased out over time but for now it is available.
Jan 08, 2010 | Sharp 13N-M100 13" TV
All we are getting is a pixilated screen and no sound. Dvd's play normally
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Aug 17, 2009 | Televison & Video
Digital converter box
A digital converter box will only allow an analog TV to to operate in analog when using a stick antenna... If you have cable or sat Tv then you won't need the converter because those companies already do the conversion for you.
If you have a HD Tv than by all means it will get HD without a converter using a stick antenna and several stations are available or will be available on cable and sat with extra fees...
Hope this helps!
Bill
Dec 02, 2008 | Philips Magnavox 20MS3442 20" TV
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo Logo
304 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
