Question about Microwave Ovens
Kenmore model 665.9517 code error eof2. What does this code mean?
  • Microwave Ovens Master
  • 9,098 Answers
Actually, that's not a full Kenmore model number.
If you'll check the tag on the unit, it should be 3 digits, a dot, then 8 more digits, such as ###.########.
But the 665 prefix means it's made for Whirlpool for Kenmore and so F2 would mean a shorting membrane keypad.
In some models, the membrane keypad is available separately. This is a bit of a job.
In others, it is not, but the frame can be replaced, and it comes with a new keypad, and is a pretty easy do it yourself job.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 20, 2010
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Microwave Model #665 6861 1891
F6 appears to be a relay failure on the main board, but it may be a door switch or door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
My kenmore over the range microwave is showing an error code of 5E or SE . . . What does that mean?
it's the touchpad, you have to stick a new one, call a technician or buy the touchpad corresponding to your microwave oven model
https://www.applianceblog.com/mainforums/threads/51787-Kenmore-Elite-SE-error-code
Nov 05, 2017 | Kenmore Microwave Ovens
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
What does F44 error code on Kenmore Elite model 790.4890 mean?
You may be missing a digit in the model number. I believe that this microwave was built by Electrolux for the Kenmore line. The F44 error indicates that the external cooling fan for the microwave is spinning too fast. This can be caused by a blockage. Check if there is anything blocking the airflow. Make sure that the voltage coming into the microwave is correct. If your voltage is too high, then the fan will spin faster.
The fan is part 108 on this diagram: http://www.searspartsdirect.com/model-part/79048903000/0583/0125400/r1009032/00003.html . It's at the back of the deflector at the top of the microwave. This is the diagram for the 790.48903000 .
If there is nothing wrong with the fan (spinning normally), then the problem is between the fan speed sensor and the control board. This should be fixed by a professional.
I hope this helps.
Jul 15, 2016 | Kenmore Microwave Ovens
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
Kenmore elite microwave troubleshooting
<- If you had listed your error code, I would probably have been able to tell you what it means.
But of course, I'd also want the full model number from the tag on the unit.
You can also look here:
http://www.appliancepartspros.com/repair-help/appliance-fault-codes.html
Jan 05, 2014 | Microwave Ovens
Microwwave
With the full model number, we could have looked up what an F9 code means on that model.
Usually it's a failure in the inverter circuit.
Sep 23, 2013 | Kenmore Microwave Ovens
What does the code F9 means on a Kenmore Elite Microwave oven model 721-62362 manuf on March 2003
The F-9 error code indicates a defective control board, inverter or line voltage too high.
Read more: http://wiki.answers.com/Q/What_does_the_code_F-9_mean_on_a_Kenmore_Elite_Microwave_oven#ixzz1FMSrTmbU
Hope that answers your question and it won't be too expensive.
Check on ebay for prices.
Mar 01, 2011 | Kenmore Microwave Ovens
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
