Question about Denon Audio Players & Recorders
DenonUD-M5 - CD does not play. When putting on a CD the DISC IN indicator flashes correctly then there's a lot of clunking sounds and then the CD indicator light moves on to CD No 2 then repeats the process to NO 3 without any CD being played. The front display panel registers that there is a CD there and shows No 1 but does not play
  • alexandra_ca Aug 21, 2010
    No problems with CDs as they play perfectly well on other systems and are not pre-recorded. I think the problem is more to do with the changer.......but I don't know really.
  • alexandra_ca Aug 31, 2010
    Thanks for this but can you tell me how to do this?
    Genius:
  • 1,456 Answers
Check to ensure that you are playing a CD that is compatible with the player,for example playing a DVD disk on the CD player will not work
The most popular cause of this problem is playing a disk that is incompatible with the player
Also your lens might be too weak to play the CDs so you should change your lens but first try opening your CD player lens and clean the lens with cotton wool and a little methylated spirit.
Posted on Aug 21, 2010
    President:
  • 1,070 Answers
Welcome to FixYa
Dear User,
Check your CD,which you are trying to Play is Compatible Format.Check your CD for any Damage.Try with another CD.Still have any Problem it might be CD Lense Problem..
Hope you got it..Thanks for Connecting FixYa..
  • shafi
    shafi Aug 29, 2010
    Check your Lense .Which helps to read CD.
  • shafi
    shafi Aug 31, 2010
    Use any Lense cleaner first.There is CD available to clean Lense.Try it...
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
Cd-rom won't engage
Maintenance might be the issue. Open you cd rom Drive. Take a piece of cotton wool or microfiber cloth. Make it damp with vinegar and wipe the small glass eye you see in your cd rom drive. Please be as gentle as possible because that small eye is sensitive. Then try playing your discs
Jan 15, 2014 | Gateway MX8711 Notebook
Can play DVDs, butcannot play CDs. Indicates
The CD disc plays at much slower speed than the DVD, the selector ic is responsible for automating the correct speed, when this fails it cannot read the intented disc. I would use the DVD player until it gives out simply because repair cost can't be justified.
Mar 30, 2012 | Onkyo Audio Players & Recorders
I got a 765 phi lips cd recorder player and every time i put a digital audio cd to rec it indicates no disc but the right tray plays perfectly what can i do it is a very important material for my work plz...
make sure check your manul for the correct disc it could say digital audio,but look carefully on disc for scratches or dust clean lens and check disc for cd-rw or cd-r digital audio i had the 770 and have the same problem and i kept buying the wrong disc.
Jul 30, 2011 | Philips CDR775 2-Disc CD Recorder
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
Dec 24, 2010 | Pioneer PD-F407 25-Disc CD Changer
Display flashing Hello and clunking sound from DVD RW. Will not change from Hello nor will it open or close
sounds like you have broken piece moving around on the inside or broken dvd inside my youngest son put a music cd in my dvd player and didnt put it in right and it broke causing player to make clunking sound and door refused to open. The broken cd was found when player was opened up and sorry to say the tray was broken because of it
Aug 09, 2009 | RCA DRC8030N
Won't Play Games, DVD and CD fine
I am guessing that when it was refurbished, it was because of a disc drive error... so i am about 90% sure that they didn't flash the disc drive and that would be their mistake. Disc Drives have their own memory and would still be able to play cd's and dvd's without problems... but if they are not flashed correctly through a sata computer with the correct hardware, they will not play games. My opinion is that you should contact the place which you bought it from, it's not your fault.
Dec 26, 2008 | Microsoft Xbox 360 Console
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
188 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
