Question about Daewoo DWC-084R Air Conditioner
Can R22 refrigerant be changed to 134 refrigerant?
    Genius:
  • 1,340 Answers
Not unless you change every system component.The fill tube may be the same size but adding it will not make it cold at all.They are 2 separate coolants with different properties and are not compatible.
Posted on Aug 20, 2010
Which gas are refill in 210 whirlpool fridge
Hello Arushdeep Singh,
I have tried to find a "210" whirlpool,..
Sadly only finding some vague references to a
17 cubic foot OLD TIME refrigerator... (?).
The good news: If indeed you are speaking of
an "OLD TIME" unit more than 3o years ago
your gas is Freon R22...
The bad news is that is BANNED and your
choices are varied... interesting and all fairly
expensive.... (hideously expensive).
Sorry that is all I can relate on a MODEL 210.
(Lot of R22 scams going on out there... be careful).
((of course)).
30 pound canisters sell for under $800 US Dollars.
R22 FREON REFRIGERANT 15 oz CAN UNUSED eBay
May 14, 2017 | Whirlpool Refrigerators
Is the R22 gas applicable or does it have an impact to global
r22 gas has been found not to harm the environment and is available at leading hardware shops the sell refrigerant gas
May 06, 2016 | Hitachi A/C Compressor, R22, 12, 829 BTU,...
Can 22 refrigerant be used in refrigeration?
I was under the understanding that R22 was for AC units only, R134 is current along with R409 (hotshot), prior to the was R12 dated 1995 and earlier. Due to the expansion properties needed for R22, I would not mix this with any other freon.
Aug 09, 2014 | Refrigerators
Could I use r22 freon on a automobile
no. either r 134 a or maybe freeze 12 if you can find any.
Apr 21, 2014 | 2004 Acura 3.5RL
1997 Mustang GT,hooked up R-134 to low fitting can still full not charginng,compresor working,what do i need to check next.
The R134 sorry to say, should not be sold to the public.
They required a licence to buy R12 ,R22 Etc but not 134
What you do or did was let air into the system,when you hooked up the short hose. There was air in it. Now it is in the system
Also the only way to charge any A/C system,not just vehicles,is to recover all refrigerent,repair leaks,pull a vacuum,check to see if it holds,them charge to thje required oz or weight. You have know way of knowing what was in the system when you started. If you had to add you have a leak. Now you put holes in the atmosphere and help out global warming.
Not trying to be cute here,just referencing how refrigerant physics works.
You can not push in what dupont calls freon,even under pressure, unless you heat it,so it changes state at some point. Has to go in under a vacuum.
You need to pull a vacuum now, to remove the air.
While you can compress air,you CAN NOT compress the water vapor in it. In fact you can damage you compressor.
Aug 07, 2010 | Ford Mustang Cars & Trucks
Can you put a 410a air handler with a r22 condensor
No. R22 and R410 are not compatible. R410 units operate at much higher pressures than a comparable R22 unit. These refrigerants also use different types of oil which are not compatible. If you need to replace half you might as well replace the whole unit because I was told that as of January 1 of this year you can no longer buy an entire R22 unit unless it is one a dealer still has in stock. They are phasing out R22.
May 19, 2010 | Carrier 38CKC036 Air Conditioner
Dometic Quick Cool compressor freezing and evaporator coil
Could be low. First check air filter, air flow, and evap coil to see if it has restricted airflow. If all seems well, its probably low. The specs will tell you what type and how much refigerant. To access system, you will need a gauge/manifold set, refrigerant, and a piercing or line tap valve for the low pressure side of the system. Of course, first, you need to locate and repair the refrigerant leak.
Jul 27, 2009 | Dometic Rooftop RV Air Conditioner
How do I change the a/c accumulator?
you will need a garage to discharge the system.you will need a haynes repair manual to locate the accumulator .the manual will tell how much 134 refrigerant put back in system and refrigerant oil to put back in. you will need a vacuum pump to pump system down before charging it up.WARNING WHEN WORKING ON AIR CONDITIONERS WEAR SAFETY GLASSES.THE REFRIGERANT 134 CAN DAMAGES EYES .VERY HARMFUL TO INHALE.
Apr 21, 2009 | 2002 Buick Rendezvous
Can you tell me what type of refrigerant is in my a/c it is a 15 k btu dometic brisk air roof top unit and is about 4-5 years old.I can't find it on the unit also how much will it hold and if its not 134 a...
USUALLY its R22. DO NOT USE ANY REFRIGERANT TIL YOU KNOW IT NEEDS IT THOUGH. The plate is usually inside the top cover and you can read it after removing the cover. If its a 110or 220 AC unit Im almost sure its R22. And the weight listed will be the most you should try to put in it. BUT before you do that you have to put on a piercing valve. And the pressures are higher for R22 than R134A. It will ofcourse depend on the outdoor and indoor temps as to what pressures youll be running as well as fan speed. Freezing is 57-58psig on R22 so the pressure after ruinnign 10 to 15 minutes has to be greater than 57 or 58 PSIG. It is normal for some units to run for a while at a lower pressure when 1st started though so dont jump the gun.
Mar 01, 2009 | Dometic Rooftop RV Air Conditioner
I accidently added 12 oz of r410 to a r22 system,
Do a triple evac. Reclaim, flush with r22, reclaim, flush with r22, reclaim, flush with r22, reclaim. install afilter drier. Evac down to at least 200 microns. Recharge. you should be ok.
My concern would be disposing of the old "now blended" refrigerant
Feb 25, 2009 | Goodman Heating & Cooling
Daewoo DWC-084R Air Conditioner Logo
52 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
