Question about Gateway FPD2275W LCD Monitor
FPD2275w monitor monitor powers on but shuts off after 1 sec shows a picture perfect before it goes black all buttons light up and stay lit sounds like they r working
  • 105 Answers
This model will likely have 2 or 3 bad capacitors in the power supply. You can see the tops bulging. They are 1000Uf @ 10 volts.
Monitor Mike
Posted on Aug 21, 2010
Philips brilliance 230c
when black does the OCD button work on said monitor.
yes, then the source video is dead,
no, then the monitor is dead.
does the power light stay on?
all monitors have ODC, RTM or press mon. buttons wildly
get a menu? if yes, that is monitor generated.
easy ,huh,?
try your monitor on another PC or lap top, easy 2.
Sep 26, 2013 | Computers & Internet
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
Nov 08, 2012 | HP w1907 LCD Monitor
Recently when I boot up my computer I get the monitor to display an image for about 2 seconds and then it goes to a black screen. if I unplug the monitor from the back of the computer and plug it back in,...
The capacitors for the power source are failing. This causes a short burst of power to get to the lamps, but then they cannot hold a charge to continuously power the lamps. You will have to replace the monitor. I suggest checking your warranty status and replacing the monitor.
Jul 19, 2011 | Gateway FPD2275W LCD Monitor
Viewsonic n2750w turns off half a sec after power on, still sound
THE 1000 UF CAP IN THE POWERSUPPLY IS BAD MOST OF THE VIEWSONICS HAVE THE SAME PROBLEM EATHER THE 1000 UF CAP GOES BAD
OR THE 470 UF CAP GOES BAD DEPENDING WHICH ONES YOU HAVE
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
When I power up my computer the Gateway icon shows up but monitor stays black...I repeatedly hit the power button on the monitor until the screen finally shows up..and once its on it stays on all day until...
hi, these are exellent monitors. i have repaired and made good profit on these. there is about 8 capacitors on the main board that go bad. all are 470uf 25 volt. if you have good knowledge of soldering, you can perform this repair. even broken, these monitors go for 100 dollars on ebay. contact me back if you want more info on how to repair yourself.
Feb 08, 2010 | Gateway FPD2275W LCD Monitor
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
RCA 27V530T Powers up and plays perfect for about 5 min then shuts off
look for cold solder joints on primary side of power supply
Jul 01, 2008 | RCA 27V530T 27" TV
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Samsung 940BX LCD monitor 9 mos. old, Problem with monitor not staying on. You turn it on, it will come on for about 3 secs w/picture then goes off, but blue light stays on, black screen. Press power...
The IPboard part no. BN44-0012A is bad. We had to replace 5 monitors with the same problem. If under warranty call 1-800-Samsung for repair or exchange.
Korhan Balimtas
May 19, 2008 | Computers & Internet
Are TV just shut off
The high voltage power of your tv is not working only the light indicator is working . you need this to bring to the shop to fix the power supply.
Apr 14, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
273 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
