Question about Garden
What is the gas / oil ratio for an Echo 210 Trimmer?
  • 490 Answers
50:1
also you may find this manual interesting:
http://www.echousa.com/pdf/documentation/SRM210es05_112603_1.pdf
Just click the blue text once and you are looking at the whole manual. Hope this helps:)
Posted on Aug 20, 2010
What is the oil to gas ratio for an Echo trimmer
I use 50:1 for all my lawn equipment and chainsaws.
Sep 01, 2012 | Echo Garden
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 | Echo Garden
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
Need to know the gas to oil ratio for my feather lite weedeater. Model FL21
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 17, 2010 | Echo Rapid Loader, Trimmer Head
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
May 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Whats the recommended 2-stroke fuel/oil ratio for echo brushcutters?
50:1 is the ratio. the easiest way to do this is to get a small bottle of the 2 stroke oil premeasured for one gallon of gas.
Feb 25, 2010 | Echo Rapid Loader, Trimmer Head
What is the correct ratio for fuel mix for a ECHO weed trimmer..SRM-210
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Sep 04, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
