Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Gateway flat screen monitor goes black when turned on
I have a gateway flat screen monitor which suddenly started to go black after I turn it on. What can I do to fix if anything.
  • 1 more comment
  • Anonymous May 07, 2008
    mine keeps going back to 8bites what can i do to stpo that
  • Anonymous Jun 16, 2008
    black screen , white screen for brief 3 seconds at startup
  • fredmichel81 Sep 08, 2008
    Hi I have been trying to open the monitor....but I can't and I am scared to brake it.Once I took off all the screws...I still can't take off the back panel! is there anything else to do to remove it beside taking of the screws?
  • 975 Answers
Open monitor and look at the PC Board to locate some kind of DRY SOLDER or burn point , specially where a transformer is located , check re solder any solder point that looks suspicious , and try again , hope this helps
Posted on May 03, 2008
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
I have a gateway FPD2485W tft lcd monitor and i start my monitor and after it shows gateway it then goes black. How can this be fixed
bonannorl, Maybe it can be fixed. You did not give any history of unit. Only "now" stuff. Is unit covered by Gateway warranty? How old is unit? Date of manufacture? Did unit work fine connected to your pc and this black or black n blank screen thing suddenly happen? Is screen also BLANK? Have you swapped-in old monitor to prove PC is OK? Your CCFL back-lit lcd monitor no different than any other brand in it's basic design and operation. Get into my fixya profile and read some of my testimonials and solutions to black or black n blank screen problems to help in your decision to DIY fix or contract out needed repair work. Most likely 2485w has problem with it's internal "switch-mode-power-supply"/"ccfl inverter supply"!! Let me know more info about unit.
12fixlouie on fixya.
Mar 09, 2010 | Gateway Computers & Internet
Screen goes dead after 5 seconds
Sounds like the capacitors have started to fail, common problem with these monitors.
Need more information. Contact elah4@zoominternet.net and I will try to help you out.
Jan 04, 2010 | Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Black screen after a couple of seconds
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
Apr 11, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor goes black suddenly
nvdia 6600 requires a minimum of 450 Watts of power to ensure that everything works properly. So if you want to continue using your nvdia card, an upgrade will be necessary.
If you want to test to see if it is the nvidia card, you need to remove the card physically from the system, then boot with the onboard video. This action will eliminate any conflicts between the two video cards. Before doing this you may need to go into device manager and make sure the onboard video card is not disabled.
Jul 26, 2008 | Gateway 838GM (RB838GM) PC Desktop
MY MONITOR TURNS ON AND AS IT SAYS STARTING ANALOG, IT IMEDIATELY GOES BLACK BUT FOR A SECOND I CAN SEE XP STARTING
Then ther is problem with your ram,please change your current RAM and upgrade it to newer one...
Dec 31, 2007 | Gateway FPD1760 17" LCD Monitor
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
379 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
