Question about Samsung SMH9151 Microwave Oven
Microwave keypad does not respond and screen reads SE
  • Samsung Master
  • 9,047 Answers
"SE" error means you have a shorted membrane keypad.
The exact part you need will depend on the model number, which will be one of these:
SMH9151B SMH9151B/XAA SMH9151B/XAC SMH9151BE SMH9151BE/XAA SMH9151S SMH9151S/XAA SMH9151ST SMH9151ST/XAA SMH9151ST/XAC SMH9151STE SMH9151STE/XAA SMH9151W SMH9151W/XAA SMH9151W/XAC SMH9151WE SMH9151WE/XAA.
On some models, you can just order a new membrane keypad and replace it. It's cheap, but a lot of work.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On other models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job, but it costs more.
Feel free to contact me directly (and please remind me of your full model number) for more information & help and a free estimate for us to do it for you.
Posted on Aug 21, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 848 Answers
Microwave keypad does not respond and screen reads SE? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
BIZET 17A Samsung BN44 00123A Power Supply Backlight Inverter BIZET 17A Samsung BN44 00123A Power Supply Backlight Inverter
Posted on Dec 19, 2014
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: tappan over the range microwave tmv151fs. keypad
"SE" means you have a shorted membrane keypad.
There are three ways to fix this:
The cheapest but most difficult is to remove and replace the membrane keypad.
Here are the part numbers, which you can order from the Pros here (our favorite supplier) or via the Sears Parts Direct Web site.
MEMBRANE KEYPAD
5304456071 (black)
5304456071 (white)
You can replace the control panel frame, which comes with a new keypad already installed.
This costs is a little more, but is much easier.
CONTROL FRAME WITH KEYPAD
5304456078 (black)
5304456079 (white)
The simplest way of all is to replace the whole control box.
ENTIRE CONTROL BOX
5304456080 (black)
5304456081 (white)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Posted on Oct 18, 2011
Why does screen say SE
SE = Sensor Error, its reported that it could be components bent over, and touching each other on the PCB behind the keypad.
You need to be a fair bit mechanically savvy to attempt a repair, and remember to Unplug it before you do! :-)
Sep 04, 2014 | Samsung Microwave Ovens
Having an issue with the keypad - not responding
I would contact Samsung, they seem to be aware of the issue with the control panel failing on there otr model and are replacing them free of charge under there "epidemic warranty"
May 06, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Se code
Contact Samsung for the SE error message. They are fixing my microwave for free today even though it is 4 years old. Model #SMH9187ST.
Feb 22, 2013 | Samsung SMH7178STD Microwave Oven
Samsung microwave says-SE- but won't respond otherwise
"SE" means you have a defective membrane keypad.
With your full model number, I could have given you detailed instructions and parts numbers.
But without that, I'll have to just be generic.
If your model's membrane keypad is available as a separate part, that's usually the cheapest but most involved way to fix it.
Here is a handy guide with pictures showing you what's typically involved.
If it's not available separately, then you can replace either the control panel frame assembly, which comes with a new keypad on it, or the entire control box / controller assembly.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 15, 2013 | LG LMVM1935 Convection/Microwave Oven
The microwave started flashing SE the display and beeps every once in a while
The "se" stands for shorted keypad. Pretty much the keypad on your microwave is fried. There\'s a wide range of ways it could\'ve happened but you have two options. You can either dissemble the microwave and order parts online for a replacment keypad or buy a new microwave.
Oct 13, 2012 | Microwave Ovens
S-E on pad
"SE" means you have a shorting membrane keypad.
If I knew the full model number of your oven, I could give you advice.
Feel free to ask here.
Sep 05, 2012 | Maytag MMV5207A Microwave Oven
Samaung microwave, model # SMH7174WE, when you plug it in, it will read ***SE***. It was made in 2005, S/N 7MTY900412X
Hello & Welcome to FixYa
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Microwave Ovens
Screen displays -SE- , none of the keypad buttons work
The word -SE- , means systems error, the cause is a short in the membrane of the keypad. The only solution is the keypad must be replaced.
Mar 05, 2011 | Maytag Appliances Over-the-Range Microwave...
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Jul 02, 2010 | Samsung SMH7178STD Microwave Oven
Samsung SMH9151 Microwave Oven Logo
3,608 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
