Question about Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052
In replacing a faulty, pull-chain, 3-way fan (Hunter ceiling fan) light switch I unfortunately misjudged my memory and am not sure which of two connecting, wire-splice nuts the red wire from the new 77052 should connect to. One splice nut connects a bundle of 5 white wires which I believe are the neutrals to each of the 4 lights attached to the bottom of the Hunter Ceiling Fan. The other splice nut connects a bundle of 3 black wires, I believe the red wire from the replaced switch connected to the bundle of 3 black wires. I am not a 100% sure of this, however, as I did this small job over two days and didn't sketch out the wiring as I figured it was a no brainer. Now when I pull the switch chain, only the bottom light comes on. Which splice nut should the red wire be connected to: white bundle or black bundle? Do you have a link of the wiring schematic for this? Thank you! Tom from Yuma
  • 3,640 Answers
Well red is usually a hot wire. so try it and see.
Posted on Dec 17, 2010
  • carl Dec 17, 2010
    if problems, go to www.hunterfan.com and click on support, for info. and phone number.
I need a zing ear part ZE-301D+ZE-109M for a HUNTER CEILING FAN WITH LIGHT #28698
Fixya does not sell replacement zing ears. Check with a local appliance parts supplier.
Jul 05, 2016 | Hunter Dryers
Bad hunter ceiling fan light pull switch
I don't know what you mean, longer stem/chain housing to hold light fixture. You should be replacing a two wire switch only.
Feb 15, 2014 | Hunter Dryers
Hunter ceiling fan light will not turn off when I pull the chain. No remote. I replaced the switch, thinking that was the problem, and still the light won't turn off. I have to keep the lights on if I want...
Make sure it's wired correctly to the fan.The light should turn off when you pull the chain weather you have a remote or not. Also the model of the fan should be 5 digits starting with a 2.
Aug 31, 2013 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan pull chain connected but does not click on
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
Aug 16, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052 Logo
505 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
AJMAL KHAN
Gene Haynes
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
