I have the CannonBJC1000 series When I try to print an item it indicates on the printer Status monito that the ink is full. I replaced the cardrige and it still comes up the same. what can i do?
    Brigadier General:
  • 6,966 Answers
Could it be that the message is "Waste Ink is Full"?
If yes:
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
This procedure is also available with other Canon printers here, here, here and here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 03, 2008
Printer gets print command and goes through print action but no print on page. Ink cartridges indicate full.
Although "full", some ink in the path-way has dried out, and is blocking the flow of ink from the ink-tank through the ink-jets.
Try the "head-cleaning" procedure, or replace the ink-cartridges.
Oct 31, 2013 | HP Officejet 5600 series
Can't obtain correct color prints - all images appear with too much blue
please do a nozzle check
and make sure the cadriges and original ones.
Jun 30, 2008 | Office Equipment & Supplies
The printer says ink cartridges are 99% and 67% full but when I try to print a message comes up to order ink and the pictures of the cartridges have yellow question marks on them and nothing will print. I...
First, make sure there are no print jobs stuck in the queue. On the computer, go to Control Panel > Administrative Tools > Services. Scroll down the items and make sure these services are "Started":
  • Print Spooler
  • lxdx
If status doesn't say Started, right click on the item and choose Properties. Choose Automatic for Startup type. Choose Started for Service status. Hit Apply then Ok to save the settings. Retry printing. If problem continues, contact Lexmark technical support. Thanks.
Nov 14, 2010 | Lexmark X4650 InkJet Printer
Prints coming out green and orange
the print head is defective or ink cardrige is defective, (perhaps is non original replace ink cardrige)
Dec 20, 2009 | Canon i9100 InkJet Photo Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
Printer reset after commando 46
Error 46 means the waste ink tank is full, needs to be replaced and reset at a shop. Must remove the entire print engine to replace. The part is less than ten bucks, the labor is expensive.
Jun 22, 2009 | Brother DCP-330C All-In-One InkJet Printer
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Substitute ink cartridges no longer work
I have the same problem and many Canon users , i try a trick that mayby solve this and last but not least ... Mayby the only cheap solution for all print users !! jumping-smiley-004.gif
My problem .. was looking for a cardrige solution ( IP4300 ) because 4 (of 5) cardrige leds are dimmed off and need to be replaced . I just order 5 adopters and 5 new with chip for all the five cardrige . Problem : The chip uses memory and that makes it very hard to reset . But i have thinking .. mayby this is somthing ..
What you read is new, experimenting with this idea is all at your own risk !
Here is a simple markable solution Unique !!
A - First you need all 5 brandnew cardrige with chips ( please keep all ink preventions inplace )
B - You need is a 4 poles - 1.50 / 2.50 meter +/- telephone cable
C - (five) (new) OEM cardrige without chips
D - Tin and a somthing to solder
E - 5 old chips for adopting the connection outside the printer
F - A box for the 5 new chiped cardriges
Procudure :
1 ) Make of 1,5 / 2,5 meter a 5 pcs of 30 / 50 centimeter
2 ) Solder on each lengt a old chip (this is functioned as a adopter) but first remove all the (useless) electronic components and place them on the cardriges
3 ) Solder the other site of the cable to each new chiped cardrige cq / toner that still sits on the new orriginal cardriges ( our make a alternative contact if you dont want to solder )
4 ) Tape the 5 new cardriges together and *
5 ) Put it in the box and give it a save unremovable place **
6 ) Put the (5) oem cardriges with the empty old chips ) in the right ink location(s)
* ) Looking into the new cardriges : this needs a box because of the intervering with the led this not only makes it nicer but mostly because of the outside light influence .
** ) Dont turn the kid upside down our shake it . If you do , the led indicates that the cardriges are empthy our low and the countdown proces for the chip will start !
I wait for arrive of the new ones, anybody who try make a handshake !
See you soon
John
Netherlands
Jan 29, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
jasbo
jasbo
