Lets see if we can help you. Lets take the bright sunshine issue first. You can adjust the backlighting on the device which may help that situation. To do this:
1) Click on the system icon. Then select the BACKLIGHT button. Now with the backlight menu up, tap the right side of the brightness bar (the top one) until the indicator is all the way to the right (bright sun). That should help some.
For the changing the colour issue, not sure if you mean night color options or color options themselves. For night color options, tap anywhere in the top 1/3 of the screen to bring up an options menu. Then select NIGHT COLOURS to change to softer night colours when driving at night.
To change the colour scheme during the day, according to the manual, when you turn the device on, it shows the setup screen. From within the 'Full Navigator' menu, select SETUP. From within this menu, should find an option for Colour schemes. Select this to choose the colour scheme that you'd like.
These devices always have many menus and aren't too easy to navigate. Hopefully these instructions will help you find what you're looking for. The entire manual for the device can also be found at:
http://www.pronav.co.uk/Downloads/ProNav%20PNN300%20(UK)%20User%20Guide%20V1.1.pdf
Hope this helps!
Cheers!
