Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub noticed that it drains out the drain hose while filling. Does the drain hose need to extend up into the drain pipe so as not to drain while filling. Also, is the pump the likely culprit for the leak underneath while running? I could see no hose leaks under the unit.
    Champion:
  • 245 Answers
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Posted on Aug 20, 2010
Washer seems to be leaking during spin cycle.
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
May 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2, empties whilst filling. It dosent seem to be a leak but as though a valve is not working
You may have a condition known as siphoning. This is caused by the drain hose not being high enough off the floor, or not having a proper air gap in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Mar 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II washing machine that is leaking water onto the floor. The water is not coming from the back of the machine. What do I need to look for and how do I get into the machine?...
I suspect you may have a drain pump leaking on your washer. The following link explains all the steps necessary to access and/or replace the pump (if required):
http://www.fixya.com/support/r397092-replacing_water_pump
If the leak isn't too bad, allow the tub to fill about 1/3 of the way and turn off and unplug. With the exterior case removed, you should be able to see where the leak is coming from. If the leak is coming from the front of the washer, its probably your drain pump or drain hoses. If the leak is coming from the center under the wash tub, you more than likely have a bad tub seal. If the leak is coming from the side of the wash tub, you probably have a loose air hose on the air dome (with this problem, the washer will begin to leak when the tub gets to about 1/4 full). Also check all your drain hose clamps to ensure they are tight. The only other thing that can cause leaks is a cracked wash tub (not real common).
If you have questions, please let me know. I hope this helps you narrow down your problem.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is leaking even when water in waher but washer off
check out you tube search whirpool washer repair, easy to see how to remoe the panel, most likely a bad pump is cause of leak. will be quite evident!! yo can even just tip unit back the underneath is open
Feb 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer leaks
do not remove the top panel. First tip the washer back. NOT ALL THE WAY. just enoough to see under it. you will see a pump. it is attached by 2 hoses. one to the tub and one to the drain. take the 2 clips off with the hoses still attached. tip it downward. Is water leaking oout of it? let me know thanks
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSQ9244EQO washer is leaking
IN FRONT? IF SO, PULL IT OUT AWAY FROM WALL 2 FEET AND LEAN BACK AGAINST WALL. LOOK UNDER MACHINE IN FRONT, PUMP HAS 2 HOSES ATTACHED. IF LEAKING THROUGH PUMP, REPLACE THE PUMP.
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer machine leaking
check for a split in the drain hose
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
244 people viewed this question
Dan Webster
Dan Webster
Sal De
