Question about Dometic Rooftop RV Air Conditioner
I ordered a replacement relay box (Part # 3104998) for my 1998 600 Series Penguin A/C ( model # 600312.321). They sent me a 3109226.005 box that is used with 600 series A/C and other series units with more options like heat strip and phone line hook ups.. The problem I?m having is how to wirer my thermostat ( part # 3105058) to this new box. Here are the wire colors for the thermostat: Wire T?stat Yellow?. RH Blue (larger gage) W White??????.. Y RED???????. RC Blue (small gage).. H Green G The relay box has six wires two blue, two yellow, and one black, one red. It looks to me the blue wirers go to a heat strip that is not an option on my cooler. I?m lost at how to wire the thermostat to the relay box.
  • 2,272 Answers
1) Connect the previously run +12 VDC to the red wire labeled +12V protruding from the air conditioner. 2) Connect the previously run -12 VDC to the black wire labeled -12V protruding from the air conditioner. 3. Connect the two (2) blue wires from the air conditioner to the furnace leads (if applicable). Polarity does not need to be observed on the furnace leads. 4. Connect the air conditioner yellow wire to the EMS wires (if applicable). Do not allow the yellow wires to short out or touch, because the compressor will fail to run. 5. Connect the Comfort Control CenterTM (CCC) cable previously terminated (Control Cable) into one of the control cable leads out of the air conditioner. Either one of the two (2) control cables can be used. 6. Connect the remote temperature sensor lead into the remote sensor extension from the air conditioner (if applicable). 7. Connect the previously terminated (Control Cable) 4 conductor control cable into one of the control cable leads out of the air conditioner for the next zone (if applicable). 8. If the unit is a heat pump model, route the ambient air sensor cable, already installed in the base model, through the grommet in the control kit and attach it to the connector that matches its color (RED P3). ----------- check out.Keep updated.
Posted on Aug 20, 2010
Where can I order a new battery for NUVI 805 series/
The nuvi and Garmin Drive series devices do not have user replaceable batteries, with a few exceptions. The exceptions include the nuvi 500 series, 800 series, 805 series, and the nuvi 295W.
A replacement battery for the nuvi 500 series can be purchased on the Garmin website here.
The nuvi 800 & 805 series and the nuvi 295W use a replaceable Lithium-ion battery as well. Although the replacement battery for these devices is no longer available via the Garmin website, you may be able to purchase a replacement through a variety of dealers.
All other nuvi models do not have user replaceable batteries. These devices must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin International is the only approved repair facility in the United States and Canada. To request a repair for your device through Garmin, contact support.
If you are experiencing battery problems visit the following FAQ: How do I charge my automotive GPS device?
https://support.garmin.com/support/searchSupport/case.faces?supportPage=nuvi%20900T&caseId=%7B2636d650-faa8-11dc-d4b2-000000000000%7D&locale=en_GB
Mar 17, 2016 | GPS
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
While driving I lost headlights and taillights and dash lights on my 1991 GL 1500
I have an1988 Goldwing 1500 and lost my dash, all instrument, and head and taillights on a trip back to Kentucky from Florida. I sent most of the Saturday in Atlanta finding a repair shop and finally spent $95 for a technician to regain my power by doing as follows. You can loosen the 4 8 mm mounting bolts in your left saddlebag. 2 at the top and 2 in the floor. Remove the left side cover, the Fuse box cover for the Relay cover to clear, pull hard on the saddlebag at the front. Then unsnap the relay box cover and work it to the front past the fuse panel and remove it. On the back of the cover you will see a diagram of all your relays and what they control. Remove the main relay which controls your head and taillights. Pull the relay that controls you air compressor because you dont absolutely need it. Place it into the main circuit. That will restore you head and taillights. I had a short in my low beam headlight relay that took out my headlights and taillights and I was pulling a trailer and needed them both. When removing the relay it freed the circuits and all was restored except my low beams. I ordered a replacement relay when returning to Kentucky for a price of $28 each. You can match the relays up with Auto Zone Pilot fog light 30 amp relay for $8 each but they must order them because the former older Pilot Fog lights are not sold there anymore. They will fit exactly only slightly larger but will work over the 20 amp factory but you must break off the mounting tab and grind off the residue on the sidewalk or using a file in order for your Relay Box Cover to close. Then reverse putting everything back together. I hope that resolves your problem. I keep 3 extra relays in my saddle bags. You can test the relays by connecting 12 volts to the 2 side terminals and they should click. Connect an ohm meter to the other 2 and you should get a reading to infinity. If no response the relay is bad.
Oct 14, 2010 | 1991 Honda GL 1500 Aspencade Gold Wing
Trying to find a replacement cooling fan for a Averatec all in one 1130 series
i sent a feedback to the techsupport in the averatec web page explaining i couldnt find the cooling fan for my all-in-one D1130EA1E-1 and i got an email from thier tech support that this part is available. they sent me an order form. here is the email address of the tech-support contact that emailed me with the order form : jshin@trigemusa.com
i just sent check along with today so i cant give you feedback yet. but looks pretty legit.
hope this helps
Oct 06, 2010 | Averatec All-In-One D1130 Notebook
Turns over but wont start
Look under the Hood and Locate the Fuse Relay Box. Inside this Box, Locate the Starter Relay and Crank Relay and Replace these. The Diagram should be on the inside of the Cover for the Box or inside the Owners Manual. Please Rate My Response! Thanks!
Feb 05, 2009 | 2001 Saturn S-Series
Nonworking bilingual activity laptop
In order to have a replacement sent for anything, you need to know what Brand and Model it is. Does it have any names on it anywhere? If so, you can try to contact them, either through a website or phone number.
Feb 11, 2008 | Video Game Consoles & Games
Dometic Rooftop RV Air Conditioner Logo
799 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
