Question about LG LWHD1500ER Wall/Window Air Conditioner
We have a LGHD25000ER window unit. It's on a 220 line. It was working fine until last night. When you plug it in the G.F.I. on it's line from the air conditioner it pops instantley. We have already assurtained that it is not our house line nor our breaker box.
  • LG Master
  • 43,501 Answers
There has to be a shorted wire in the Air Conditioner then....the GFI is suposed to do that if it senses a short anywhere in the circuit and if it is happening when the air is plugged in then it must be in there....
heatman101
Posted on Aug 20, 2010
Testimonial: "thanks guys! You helped a ton!"
Purchase an friedrich 1400 btu last year from pc richards was working well until last night when I turned it on the light came on heard it humming and then it turn off my surge. What could be wrong with...
Take the surge supressor off the unit, or it better be a good one, and its best not to have it plugged into any thing, just straight into the plug in, and your unit is 14,000 btus
Jul 04, 2011 | Friedrich Heating & Cooling
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Air worked fine all last night and his morning.
if the air comes on for a short time and then turns off for 15-30 minutes, the overload protection inside the compressor is shutting down to protect the compressor. this can be caused by blocked supply or return vents, improper charge, bad valves in the compressor, and a multitude of other things. the problem will have to be corrected first.
Dec 14, 2009 | Heating & Cooling
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Need information on the btu
Hey, Back -on line , & the answer to your question is ...go to webpage or type in whirlpool model window unit mod acq189! This equals to 17,800 btu 15 amps 220 volts 3 speed.
Jan 08, 2009 | Whirlpool Heating & Cooling
Samsung window air conditioner model aw05ncm7 icing up not cooling
After I opened the front of the unit and discovered it full of ice, I left the unit off until it defrosted, so to speak, after the ice had melted, I turned the unit back on to see what happened. It is working fine now, I'm not sure why it iced up, if this is normal or not, but after it melted the problem was solved.
Jul 22, 2008 | Heating & Cooling
Fridgidaire ac window unit
More than likely this unit could be fixed reasonably. It sounds from your explanation like a bad connection inside the control panel of your unit. Could possibly be what is called a cold soldered joint.
Jul 18, 2008 | Frigidaire FAC126P1 wall/window Air...
My haier window air conditioner
I have a haier unit and last night the led went crazy it has totally stop working now and the LED just shows E1 I have tried unplugging it and resetting the button on the plug and nothing has helped this unit is less than a year old. Please help if you can....
May 18, 2008 | Whirlwind FH-778 Air Conditioner
LG LWHD1500ER Wall/Window Air Conditioner Logo
190 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
