Question about Maytag Refrigerators
Ice maker has stoped making ice - Maytag Refrigerators
    Champion:
  • 245 Answers
Check to see if you have ice build up in the water tube behind the icemaker. Sounds like your inlet valve is bad behind the back panel on the bottom. Good luck!
Posted on Aug 20, 2010
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Ice machine stoped making ice?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 10, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Has stoped makeing ice and none of the door controles work. model SH205298
heatman101
Aug 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stoped working
heatman101
kgljlgkqerqer
Jan 22, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker stoped
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker stoped making ice
Hi
Thanks for using FixYa. Check to see whether the ice maker has been turned off. Here's how to check.
Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | Kenmore Refrigerators
Ice maker has stoped making ice. The bar that cuts it off when enough ice is made moves a little while in the up position.
lifting the bar to the full up position is how you stop the ice maker from making ice. move the bar back down and ice making will resume.
Mar 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Changed filter, red light flashes, not making ice at all
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Refrigerators Logo
42 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
