Question about BenQ FP231W 23" LCD Monitor
My BenQ FP231W has a Blue square in the top right hand corner about 4inches by 3inches -it remain blue at switch -on even when not connect to the computer -Nothing appears in that blue square even when connected to computer.
MicrowaveSvc
  • 9047 Answers
SOURCE: benq monitor fp51g
What's the owner's manual say that means?
Posted on Jan 15, 2007
Mark_Webber
  • 472 Answers
SOURCE: BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Posted on Apr 09, 2008
SOURCE: Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Posted on Dec 29, 2008
Professeur_D
  • 42 Answers
SOURCE: wont power on
Check to see if the video cable is connected at both ends securely.
Also, if possible, try another cable.
Posted on Aug 31, 2009
  • 4090 Answers
SOURCE: wont power
Power leak causing overload on the O/L sensor.
Probably a faulty capacitor on the power board
Posted on Sep 07, 2009
How do I change the language on me Nextbook 9 from Spanish to English
If you click (on the main screen) in the top right corner on the (6) little squares. Then slide through the pages on the first tab. Do this until you see a picture icon of a grey square, outlines in blue with blue lines and dots on it. The first line will be slightly farther to the right than the second and the bottom (third) bar will be almost completely across the box. Select that. Then on the left hand side look slightly farther down the mid ways. you will see a choice that has a picture icon that looks like a sticky note with "A" on it and beside it will say "Idioma y entrada". Select that. at the top on the right select "Idioma" Then scrol and select "English(United States)". Unless you are in the UK, Select "English" UK
Jan 07, 2017 | Cell Phones
Wheer is the wirless switch on a inspiron 1545 laptpo
It is not a switch
look on the keyboard and look at 'F2' button and press it
this is the button which turns on the wifi
note the f2 key says f2 in blue and then shows a wifi signal icon in white also note a blue square box appears as you switch on and off your wifi connection in the bottom right hand corner...
Jun 01, 2011 | Dell Inspiron 1545 Notebook
Blank Blue square on left hand corner of the screen ??
It might not be the same issue, but we had a blue square in the upper left hand corner of our hanspree. To fix it, either press the button headed 'pip' or go into menu, down to calibration and then uncheck the box titled 'pip' there. I hope this sorta yours as it did ours.
Nov 10, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
I need wiring diagram for Belle 150 cement mixer 110v
Small BLUE at top right hand corner, then the two rows of two...
top left is BLACK, top right is GREY, bottom left is BLUE from the power supply and bottom right is a short BROWN wire with a spur, which leaves a BLUE to connect to the spur. should be it :)
Oct 09, 2010 | Garden
Switch connections
I have a Jenn-air, and the switch for blower and light is on top, front. the switch has 4 connections on the bottom, and viewed from the bottom, the white wire goes at 12 o'clock, the red and brown wires are in the top left corner (paired with the white one) and the black wire is at 6 o'clock, and the blue (double wires) goes in the lower right corner (paired with the black one). If you have a continuity tester, the switch is a dpdt, and white is connected to red-brown (double wires) OR black is connected to blue-blue( double wire).
Hope this helps.
Aug 26, 2008 | Kitchen Ranges
Olevia 540-B11
damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
Aug 19, 2008 | Olevia LT42HVi 42 in. LCD Television
Secondary monitor
When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
And yes please check with BenQ Normally these have a 3 year warranty.
Mar 05, 2008 | BenQ FP757 Monitor
Channel information icon
This icon is sent by the channel itself and cannot be removed!
Jan 05, 2008 | Televison & Video
BenQ FP231W 23" LCD Monitor Logo
156 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
