Question about Dell Dimension 4550 PC Desktop
Dell dimension 4550 ethernet driver please - Dell Dimension 4550 PC Desktop
  • 1,879 Answers
Dell dimension 4550 Ethernet Driver Installation Guide
1. Go here to download and install the Chipset - Intel driver.
2. Restart the computer.
3. Then go here to download and install the Ethernet driver.
4. Restart again.
Posted on Aug 20, 2010
  • Dell Master
  • 3,606 Answers
Hello Download here:
http://www.dell.com/support/drivers/us/en/19/Product/dimension-4550
Select network and download the driver.
You have to try one of the drivers because here are many different ones.
Here is only drivers for win xp.
Good luck
Posted on Dec 11, 2012
4 Suggested Answers
voodoomox
  • 1689 Answers
SOURCE: ethernet driver
you can get the drivers from the link below for free...
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4700&os=WW1&osl=en&catid=&impid=
just select your specific needs and it will give you the drivers for every component on your Dimension.
hope this helps out, if you have other issue please lemme know.
Posted on Nov 04, 2008
mysleuth
  • 142 Answers
SOURCE: download audio drivers for my dell dimension 4550
From link included select your version from (3) and sound card driver, download and install as instructed. I also recommend check out Dell support for 4550 PC at this link. Please rate me mysleuth
http://search.dell.com/results.aspx?spf=Dimension&ssysid=DIM_PNT_P4_4550&ssysn=4550&s=gen&c=us&l=en&cs=&ec=&ira=False&cat=sup&subcat=dyd%2F3&rf=all&evl=&nk=f&k=dell+dimension+4550&p=1&nf=&rpp=12&sort=K&~srd=False&ipsys=False&advsrch=False&p=1
Posted on Mar 19, 2009
  • 551 Answers
SOURCE: Dell Dimension 4550 Ethernet Hardware not working,
Have you tried restoring your operating system? If not, please do so. There is a problem with operating system and the driver of your ethernet hardware. There might be a conflict on it.
Posted on Jul 13, 2010
Which ethernet drivers worked win xp compatibilty to drive worked with embbed with ethernt i217LV
If it is Dell computer, download the drivers from their support area, used the machine's express code or service tag to find it's information.
May 02, 2014 | Dell J0592 / 0J0592 DIMENSION 4550...
Tip
Dell Dimension 4550 Ethernet Driver Installation Guide Here are the steps on...
Here are the steps on how to properly install the Ethernet Driver for the Dell Dimension 4550:
1. First click this link to download and install the Intel Chipset Driver for your computer model.
2. After the driver installation is complete restart the computer.
3. Then click this link to download and install the Ethernet Driver.
4. Restart the computer again.
Other software downloads for Dell Dimension 4550 can be found here.
on Aug 20, 2010 | Computers & Internet
Linksys em1578 Driver
Look here under Downloads
Just use the link above, select your hardware version...and you're there.
Oct 29, 2013 | Linksys Etherfast 10/100 Lan Card Lne100tx...
I have an old Dell dimension 4550, I just got it from a friend, the enternet wont work. It says no wirelless or wired devices found and no drivers. I downloaded drivers onto a flash drive and tried to...
hi your problem is that you should set the connection to internet
Dell Dimension 4550 (Pentium 4 2.66GHz, 256MB RAM, 60GB HDD, XP Home)
first you need to go to:
control panel>system>device manager>check if appears the ethernet car if it does then.
go to control panel>network conection>properties>select tcp/ip go to properties check and make sure the option of automatic ip and the automatic dns select it and you are ready....
May 27, 2011 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550, OS = WINXPPRO. Just reformatted and reload OS. Got and installed drivers from Dell.com. System sees onboard ehternet but says no driver for a PCI communications device. Cannot...
Dell Dimension 4550 Drivers
From the above link you can download the required drivers. There are two drivers available for Broadcom and Intel. I suggested try the Intel Drivers (as your system may be having the Intel based Ethernet)
To PCI communication Controller (Modem) you have to install the Modem Drivers
Trt Eicon (recommended) Or broadcom conaxant etc
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 Ethernet Hardware not working, cannot reload drivers.
Jul 12, 2010 | Dell Dimension 4550 PC Desktop
I install new windows and ethernet controller is not working and I can't get on the internet? What can I do?
Purchase a USB memory-stick.
On another computer with Internet access, access: http://support.dell.com and select "Downloads and Drivers". Select "Dimension". Select "4550".
Select "Network Adapters". Download the device-driver, copying it to the memory-stick.
Move the memory-stick to your computer, and "install" the device-driver.
Feb 02, 2010 | Dell Dimension 4550 PC Desktop
Reinstall Ethernet Adaptor after Reinstalling O/S
Does the ethernet card have a yellow or red checkmark. If its yellow, select the device and then select turn it on. If it's red, right click on it and select uninstall. Rebbot Windows and allow it to find the card or at least provide an error.
Mar 24, 2009 | Dell Dimension 4550 PC Desktop
Download audio drivers for my dell dimension 4550
Mar 19, 2009 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 PC Desktop Logo
1,670 people viewed this question
Alun Cox
