Question about Ovens
I have a Baumatic fan oven that is now displaying FBED on the LCD and i am unable to get the thermostat to respond. please could you let me know what could be the problem.
SOURCE: baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Posted on Dec 13, 2007
SOURCE: Baumatic oven not heating up
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Thanks,
Chris
Posted on Mar 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
ginko
  • 19396 Answers
SOURCE: Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Posted on Mar 03, 2010
Testimonial: "Thankyou very much for your help.Im off to buy an element first thing in the morning. Thanks again"
We have just bought a Baumatic osf60 oven, but unable to locate a manual online. Help please
where did you buy it .I would try the manufacturer through their website if they have one
Jul 26, 2015 | Baumatic Ovens
Electric oven dont work
sounds like the heating element, also check the thermostat
Apr 06, 2010 | Baumatic B180 Electric Single Oven
My Baumatic oven now displays F4E0 after a power surge, the fan still works but there is no heat.
more than likely the heating element blow but check to see if theres a fuse in line with that element
Jan 23, 2010 | Baumatic B187 Electric Single Oven
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Fan works but oven doesn't heat
Check at the terminals and look for burned wiring
Sep 24, 2009 | Ovens
Electric fan oven overheating
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Mar 01, 2009 | Equipex PZ-330 Electric Single Oven
Oven fault code
I think your thermostat is broken, try replacing it with a new one.
Oct 15, 2006 | Baumatic B205SS Stainless Steel Electric...
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
