Rewiring 84 s10
Im rewiring my 84 s10 v8 swap, Ive gutted my cab, no dash needed,. I need to know what wires out of fusebox start, and which ones to run motor. Im running tahgo switches to everything, including horn,wipers,etc. I need to understand what colors do what?
  • 611 Answers
Black wire will came out from the fuse box. red one will run the motor and bule will the collecthe power
Posted on Jun 10, 2008
Old home, a electrical outlet actually has a fuse connected right to it. How to replace/install a regular outlet plug? I have a pic, but site doesn't appear to have a place to attach it.
electrical work is not for DIY
some one has messed with the electrical wiring of the house so get in an accredited electrician and consider having the house rewired using the correct ELB devices in the power box
Jan 11, 2017 | Microwave Ovens
Would like info on easiest way to rewire dash on 72 Camaro ss
buy a genuine chevy wiring harness for the dash which will include the fusebox inner. it is quite a job and the part is over 500.00 good luck
Apr 27, 2015 | Chevrolet Camaro Cars & Trucks
I got a 1991 s10 singel cab 2wd some one cut all the plugens off all the wires it had a 4cylender and im trying to put a 350 in i an i need to know what does each wire go to
If you are changing the engine the purpose of all those wires is a moot point. Most of them are for sensors and actuators that may or may not exist on the V8 and the 4 cylinder ECM will not run the V8. You need to find a wiring diagram, a multimeter and a jumper wire to make sure what wire is connected to what in the dash or you will be replacing all the wiring in the dash along with the printed circuit on the back of the instrument cluster.
Mar 01, 2015 | 1991 Chevrolet S-10
Need to know where my power wires are on my 1991 s10 singel cab 2wd had a 4cylender changeing to a 350
This firing order is molded into the stock intake manifold towards the front (between the water outlet and the carburetor) It is 1-8-4-3-6-5-7-2; see the attached diagram
How to rewire a renault 9 gtl '84 dash board
Start by getting a current schematic. If you are doing the whole dash, I would investigate several manufactures that have a pre-built wiring harness. Otherwise, buy some automotive wire and have at it.
May 01, 2014 | Sunbeam 1964,1965,1966,1967 Tiger...
Engine Swap
you will need a new bell housing and i would change the radiator
Apr 13, 2009 | 2001 GMC Sonoma Extended Cab
My 84 blazer wont shift
Your 84 wiring harness is for the TCC ( transmission converter control) system.
On the left side of the carburetor (driver side) you should have 2 cables, one for the accelerator and the 2nd for the TV (throttle valve) control. You will need to adjust the cable for correct shift points. Under normal circumstances you will have 7 to 10 mm's extending beyond the cable adjuster block.
Should take care of the issue for you.
Let me know.
Apr 05, 2009 | 1984 Chevrolet Blazer
1984 s10 catalytic converter
Catco makes a nice very in expensive Convertor
this one in link is a direct replacement for a stock 84 Blazer
if you are not all that mechanical take it to a muffler shop they are usually cheap to cut out and swap please make sure that your current exhasut is the still stock or you will need to know the diameter of the pipe they used
Feb 18, 2009 | 1984 Chevrolet S-10
1998 ford motor swap 8cyl to a six inline
Unfortunately, You will need to Change it all. None of the V8 Components will Transfer to the Inline 6. Please Rate My Response! Thanks!
Feb 02, 2009 | 1998 Ford F150 Regular Cab
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
