Question about Zanussi F1045W Front Load Washer
How do I remove and refit the door seal? I'm managed to remove the clip at the front but something I cannot see is attaching the rubber seal at the back.
  • Zanussi Master
  • 3,463 Answers
There is another retaining band , clip, or spring holding the seal to the front of the drum, you need to remove this to remove the sea,double the seal back inside the drum to expose the retainer.
Posted on Aug 20, 2010
Remove brake booster
remove the brake pipes , and the rubber hose with the plug. now go to the drivers foot well.need a torch to see .remove the two nuts holding the booster on .then lift out the front of the car. .now remove the master cylinder from the booster . now chance to change the seals in the master cylinder get a seal kit lift the rod away. remove the cir-clip lift out the plunger change the seals . refit to new booster and refit. bleed the system.
Dec 21, 2013 | Cars & Trucks
Front door rubber seal
Fairly easy to do. It is held on with 2 wire rings, one on the outside edge of the seal when you open the door and when that is removed there is another one holding it to the outer drum. Removal of the lid may also help with removal of the inner ring. When refitting you press the lip of the seal over the outer drum edge and fit the retaining ring back and then do the same on the front where the door meets the seal. Just make sure the small drain holes in the seal are located at the bottom, best to look at the old one to see how it's fitted before you remove it.
Dec 27, 2012 | Electrolux Washing Machines
I need to refit the rubber door seal i managed to take it off but not sure how to fit the retaining metal band
its quite simple if you removed same....Assuming you have refitted the door boot seal the inner ring is normally fed on then tightened up with a securing screw some rings are a spring which needs to be stretched on to the seal, a good video is available at utube .com FIT DOOR BOOT SEAL
Jan 02, 2011 | Whirlpool Washing Machines
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
Grey scum marking clothes
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Mar 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Replacing a rubber door seal on washer machine
1. Remove door (2 screws).
2. remove top (2 screws at back, sharp slap to front to dislodge).
3. Remove 2 screws holding powder dispenser to inlet valve.
4. Remove 2 screws at front corners securing fascia.
5. Remove fascia and powder dispenser as a unit - note plastic locating pegs on underside and plastic clips locating bottom onto front panel. Take care not to drop one of the rubber seals from valve/powder dispenser joint. Do not disconnect the wiring, just lay the complete assembly on top of the machine.
6. At some point, you will need to release the retaining wire securing the seal to the front panel. This is a thin spring loaded wire. Look after it, you will need it again.
7. Remove two screws at front securing front panel.
8. Remove kick panel - this allows access to two more screws securing bottom of front panel - take these out as well.
9. unclip the wire connector to the door switch.
The front panel may now be lifted from its plastic retainers.
10. The second wire clip can now be removed. The clever clip will need to be released to allow refitting.
11. Thoroughly clean and disinfect the seating for the new seal - you don't want the same gunk growing into the new one straight away.
12. On the drum, you will notice a protruding moulding at about 5 o'clock. There is a matching flange on the seal to help you locate it accurately - start here and fit the seal.
13. Fit the wire retainer - you will need a good pair of long-nose pliers to retension the wire.
14. Reassemble the machine in the reverse order - take care not to mix up the screws! remember to fit the seal to the front panel before refitting the door. Do not release the spring from the wire, carefully stretch it into place.
Aug 27, 2008 | Ariston Technologies AWD120 13 lb. Washer...
The top of the rubber door seal has come away from the wire that holds it in how can I put it back
first remove the wire retainer (usually has a spring attached) then fold the rubber lip of the door seal back over the metal lip on the front of the machine when correclly positioned refit the retainer by starting at the recess where the spring sits and stetching it all around the seal making sure that it is sat in the groove where it fits, it is fairly easy to replacestarting from the spring and following around clockwise making sure that it is seated right as you reach the other end of the spring the spring will stretch allowing you to finish tucking the wire in and the spring should then tuck in to the recessed part of the seal
Jul 19, 2008 | Bosch Washing Machines
Bosch washing machine
i am recently retired appliance engineer of 20 years, the rear door seal clamp is generally nowadays a large thin spring that is slightly hidden by the concrete weights at the front of the drum, if thats the case the door seal will just come off with a good firm pull round the drum edge, fitting as a reverse of removal, place the door seal in the groove so it fits like it should, then stretch the spring and fit that into the outer groove round the lip of the door seal at the drum end, once that is done fit the seal on the front panel lip, then replace that clamp, check all is fitted securely before running machine its one of those jobs that hard to explain how to do it, hope i have helped a bit, its easier to work through the front door opening than from above? if i have please rate me thank you
Sep 13, 2007 | Washing Machines
How do i fit a new door seal???
disconnect from mains not that easy first time. undo clip holding seal to cabinet. peel off seal and push inside drum remove top.i remember seal is held to tub by a giant jubilee clip but varies with model. undo clip and remove seal complete. fitting is more difficult lubricate slot that fits flange of tub with washing-up fluid - essential start at top fit an inch or so of slot onto tub flange. work in both directions forcing slot onto flange with thumbs as you go round. refit giant jubilee clip. refit seal to cabinet and refit cabinet clamp. test for leaks on rinse as water level is higher. this job is a knack so persevere
Mar 28, 2007 | Candy CN126 Front Load Washer
Zanussi F1045W Front Load Washer Logo
186 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
