Question about Sloan 3010100 110 Water Saver 3.5
Have a urinal flush valve which has insufficient water discharge. Unit is supposed to dispense 1 gallon, but I would estimate only about a half liter flush. Any suggestions?
  • 43,501 Answers
The guts have worn and the hadle does not push the internal plunger far enough. Check your local plumbing supply house for a rebuild kit. The kit can be installed in a couple of minutes.
heatman101
Posted on Aug 20, 2010
Put new valve in the urinal, flushes fine, but loud groaning noise in the wall after every flush, didn't happen until new valve put in. What can I do?
air chamber shock absorber ,wrong pressure take cap off adjusting screw and adjust.it the big silver cap on top just screws off.
May 26, 2015 | Sloan 180-1 Exposed Urinal Flushometer -...
Have a slow drip in water dispenser GSS201EPWW Gen Electric fridge
Most likely you need to replace the water valve first try running at least a gallon water through it to flush it out if that doesn't work new valve is needed
Jan 23, 2015 | GE GSS20IEP Side by Side Refrigerator
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
Rotten egg smell
Mix one quart (liter) of distilled white vinegar with one quart (liter) of water. Pour the mix down the drain. Let it stand for half an hour, then flush it through with a couple gallons of water.
Jan 20, 2014 | Plumbing
How do I increase the water pressure when flushing a wall-mounted urinal?
I don't know witch valve you're working with but most volume control adjustments are located under a screw off cap on the front of the valve. Remove that cap and there will be a small slotted screw that when you turn in it reduces the flush time and out increases it.
Feb 08, 2011 | Eljer 161-1190-00 White Bedfordshire Wall...
Im cooking fish, how much oil ?
Enough to submerge the fish in the basket. Easiest way to get it pretty close:
1. Place the basket in the cooking pot.
2. Fill to the estimated displacement with water. The estimated volume would about half the height of the basket in the pot, if you were to fill the basket with fish half way. This way you know that you'll have enough to cover the fish when you start frying.
3. Measure the water. If you have the markings stamped in the side of the pot, this is pretty easy. Otherwise, pour the water into a gallon jug, keeping tally on how much water you removed from the pot. A partial gallon at the end is easily estimated. Works the same for liters, depending on where you live.
4. Dry the pot thoroughly before you add the oil.
Best regards, --W/D--
Jan 28, 2011 | Eastman Outdoors 38065 Turkey Fryer
Fabric Soft and Bleach despenser on MAYTAG TL FAV6800 won't drain
I'll see if I can help. Can you just clarify if by won't drain. Does it look like no water flow is flushing the the Bleach and Fabric Softener dispensers?
The Fabric Softener dispenser could be clogged but I suspect the dispenser’s valves are not opening to flush the dispenser’s. If the Fabric Softener dispenser is clogged you can flush with White Vinegar solution and clean exit port with a pipe cleaner. I do not suspect a clog with the Bleach dispenser.
You could go into Service Mode and turn on the water valves for the dispensers to check if water is sent to the dispensers.
If you have no water flow to the Softener dispenser here is the non technical troubleshooting I would take. Go into Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open. Do the same process for the Bleach dispenser water valve with Bulky Items Key Pad.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach/Fabric Softener dispenser valves.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price.
Good luck…….Rich
Mar 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Urinal leaks need help
You will have to shut water off, that is what the screw does(so it can be worked on). you will need 2 pipe wrenches, always use 1 wrench to back up or hold fixture when using other wrench to open valve. That said with top of valve off now you can replace the flush valve diaframe. You can go lowes or some other improvment store/
Sep 19, 2009 | Toto TEU2DNS-11 Commercial Electronic...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Sloan 3010100 110 Water Saver 3.5 Logo
119 people viewed this question
Top Sloan Home Experts
richochet
ray gallant
Ted Maxwell
Are you a Sloan Home Expert? Answer questions, earn points and help others
