Question about RIM BlackBerry Pearl 8100
How to replace the battery in Braun Model #5314 shaver
  • Anonymous May 18, 2008
    Same problem. I have found and removed the 2 "hidden" screws at the base of the unit (on either side of where the adaptor is plugged in), but am afraid of pulling apart the case in case I break it. Has anyone done this successfully?
  • Anonymous Jun 11, 2008
    remove shaver head (2 screws)
    remove 2 screws at the bottom of unit.
    with coin, turn plug socket.
    now pull carefully cover.
    you'll need a welder to replace the 1.2v nimh rechargeable battery.
I went through Solution 1 and it worked for me. Thanks! Soldering was hard for a beginner. One note: Do not attempt to turn back plug socket with coin. Instead, try to push the plasticky little thing back that was moved by turning.
Posted on Sep 22, 2008
Remove shaver head (2 screws)
Posted on Jun 11, 2008
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
My braun 5314 does not switch on
Most likely, the battery needs to be replaced. Compatible battery type can be found at shaveroutlet.com
Shaver Replacement Battery AA NiMH
Jul 04, 2015 | Braun Flex Integral 5314 Electric Shaver
Where in Australia can I buy a foil
You can purchase a new foil for Braun model 5314 at shaveroutlet.com and have it delivered to your mailbox in Australia. See link below to webpage
http://shaveroutlet.com/shaver-replacement-parts/braun-5000-6000-series-flex-integral-flex-xp-foil-p-350.html
May 06, 2011 | Braun Flex Integral 5314 Electric Shaver
Braun shaver 5314. The green light works when plugged in. Does not hold charge to work at all. What is the problem, can it be fixed or should I begin looking for a new shaver?
Battery is dead. You will find compatible battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Remove foil and cutter. To open the shaver, pry off the two screw covers on the bottom and then remove screws. Remove the swivel fram on top by removing the two tiny screws. You can then gently pry the two halves apart from the bottom. You will be able to access the battery pack once the case is seperated
Dec 28, 2010 | Braun Health & Beauty
How do you open a Braun 5314 Shaver to replace batteries?
You will find replacement battery at shaveroutlet.com. See link below
Start by removing the foil and cutter. Then remove the swivel frame by removing the two tiny screws on each side of the inside of the swivel frame.
To open the shaver you will first need to remove the two round screw covers on the bottom. Then remove screws. You can then gently pry the two halves apart from the bottom
Sep 30, 2010 | Braun Flex Integral 5314 Electric Shaver
Need replacement battery for braun Model number 5000-type 5724
Shaver Replacement Battery AA NiMh type
NiMh shaver battery pack with easy solder tabs, dimensions of battery are 1 11/16 length x 9/16 diameter. Battery is 1650 mAhWill fits several older model Braun shavers, $9.99. Contact http://shaveroutlet.com/ for detailed info. Older model Braun shaver batteries don't come on a circuit board and involve soldering.
Since I have never dissembled this model ask Shaver Outlet via e-mail if you buy the parts from them. They have been most helpful to me.
Jul 01, 2009 | Braun Syncro 7526 Electric Shaver
RIM BlackBerry  Pearl  8100 Logo
138 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
