Question about Buck Pontiac G6 2005-2007 05 Stereo/radio Wire Harness Plug
I want to replace my Pontiac G6 radio. But I want to keep my "info center" display intact. Is that possible?
There is a kit from Metra called the Metra 99-3303 kit that takes the double din area of the stock stereo and converts it into an info center/single din. Cost is about $123 on ebay.
Posted on Nov 21, 2010
Why is the display on my car stereo not working in my 2010 Pontiac G6
The tiny display bulb is burned out, you must remove the radio and have the bulb replaced, it is soldered to the circuit board and it takes special tools and skill to replace it.
Feb 12, 2017 | 2010 Pontiac G6
After changing the battery on my 2005 Pontiac G6 the radio will not display anything. Not even the
did you hook the cables up backwards (ground to positive) as this could short out your electronics. are there any other electronic issues. if you didnt and everything else is ok you radio may have an anti-theft program. you can try disconnecting the ground connection to the battery for about 30 secs and reconnecting it. if it still doesnt work look in your owners manual how to reset the computer also check your fuses.. if all fails you may need to get the radio reprogrammed good luck
Jun 16, 2012 | 2005 Pontiac G6
Remove center console in a pontiac G6
May 26, 2012 | 2006 Pontiac G6
I accidently did something the display for the clock/radio ??!!! the display previously show time display & now it shows the radio station name RE: the radio station I listen to is 105.7 (KHCB) and ...
continually press/release the center of the tuning know until you have the preferred display you want and then press and hold the same button until the system beeps (1-2 seconds). It will now save your preferred default screen (clock in your case)
Jan 14, 2011 | 2006 Pontiac G6
Replaced the bat in 2007 g6 now the radio will not power up ,,, why
If it is a factory radio,whenever you remove the battery the radio goes into a locked mode.You need to call a Buick dealer to get the unlock code and have them tell you how to do it.Write down the code for the future possibilities too.Good luck! Greg
Aug 28, 2010 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
Pontiac G6--Instrument panel lights up and transmition jerks hard
try having the fault codes read to determine the fault area
Jul 10, 2017 | 2007 Pontiac G6 GT Convertible
Pontiac G6 please help
newer cars come with an amp built in so mak esure u hook up the amp wire it may end up plugging into the power ant. or amp wire
Dec 07, 2009 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
Pontiac G6 radio
probably not but the switch over is ez you probably need a harness..thats about it..
Jul 10, 2009 | 2008 Pontiac G6 Sedan
Car will not start after I pulled the fuse for my radio
Thats because on the G6 your entire control center and brain of your car is ran through your radio. Without the fuse to your radio, there is no current getting to the controllers for the G6's quick click auto start feature. The G6 does not use a regular starter cylinoid like most cars older than 2004-2005. The controlling signal of starting your car when you click your key over for that split second is run through systems housed and integrated in the radio.
Mar 01, 2009 | 2006 Pontiac G6
Buck Pontiac G6 2005-2007 05 Stereo/radio Wire Harness Plug Logo
833 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
handygirl911
handygirl911
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
