Question about Sony VAIO VGN-NS140E/S Notebook PC
Ok when I turn on my laptop it boots up and starts working but after I sign in my screen goes blank (black) so I hooked up monitor and I can see the video card is working.. Now the funny thing is if I let it sit for a while of power down, when I wake the PC up the screen works for about a min then goes back blank...
    Sergeant:
  • 238 Answers
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Posted on Aug 20, 2010
Xps m1530
Sounds like your video chip or your backlight. Hook up an external monitor. Does it stay on or the same results.? How long before it goes off/BLACK ???
Jul 05, 2013 | Computers & Internet
I have a year old sony vaio vpcee31x screen goes white on boot up and while on then later returns to normal. did a restore it worked ok for 1 month them started again. its only the screen that goes blank...
The problem is in the LCD display intermittent, or a possible loose video cable from the screen to the motherboard. But first, hook a spare monitor to the video output usually on the back, if okay! it is one of the problems outlined above. If symptoms are the same, the Video Graphics Card is bad usually built into the motherboard.
Mar 17, 2012 | Sony Computers & Internet
Thinkpad blank screen
Once you run safe mode. You can turn off the laptop. Then start booting normally.
Mar 02, 2012 | IBM ThinkPad T20 2647 Notebook
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
My srceen goes Blank
first try booting the laptop and pressing the Fn key with the numerical ( numbered key ) that has a picture of 2 screens on it. This is for booting to an external monitor. you could also try adding an external ( pc monitor ) this will eliminate any motherboard Faults.
Secondly, the graphics chip driver may be corrupt or not installed correctly. if you have a restore cd, you could try booting the laptop, with the cd in the drive.
you can then try, to see if the settings in the bios are all correct, by booting/starting the laptop and pressing esc or F2 or delete immediately as the laptop starts. ** Be-Careful** what you adjust.
My suggestion is to look for. ** default settings tab** or load setup defaults.
these are the obvious things to try, before assuming that you have a faulty graphics chip or motherboard fault.
Mike @ compurepair.
Jun 12, 2009 | Acer Computers & Internet
Screen won't turn on
when u power up press F8 key then enter in enable vga mode then change screen resolution to 1024*768 then apply and ok thats it.
Jun 09, 2009 | Computers & Internet
Black Screen
hi, try boot to safe mode, check the display properties, settings and the refrsh rate. if not solved, reinstall the graphics controller driver..
thanks
Aug 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Fujitsu c series labtop screen goes blank, the hooked up to a monitor, starts to work then says out of frequence and goes blank
The video resolution and/or frequency that's set in windows is not supported by the monitor you have plugged in. Restart the PC in VGA mode (hit F8 after the BIOS messages but before any Windows messages) and change the video settings to something basic, such as 800 x 600 @ 60 Hz. Then restart the machine normally.
Jan 21, 2008 | Fujitsu LifeBook C6555 Notebook
Repair installation
Sorry to cover the basics but you cant be too careful. have you set your bios to boot from cd? Also when the cd tries to load you should have to tap any key to go into it. If all these thing are covered you have two more likely faults. 1. Faulty Ram. 2.Faulty drive
Aug 14, 2007 | Acer Aspire 3680 Laptop
Sony VAIO VGN-NS140E/S Notebook PC Logo
104 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
