Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Meat spoiled over three week period in standup deepfreeze. Odour Contaminated freezer and general area with meat and fruit spoilage. Have cleaned everything with bleaches disinfectants and commercial deoderizers but still have lingering odours in both freezer and general area. Have also tried , "OZIUM" a commerecial deoderant which has reduced the odour but has not elliminated it. what can you suggest?
  • 4,793 Answers
Use a strong solution of clorine bleach(in a spray bottle) to get into every nook and cranny/drainholes/drip trays/door seals and wipe dry(clorine is a gas and will dissipate within an hour or so)then wipe over interior with a damp cloth and plenty of bicarb,leave to dry and leave any bicarb residual inside fridge as this will absorb any smells left.leave door open for about a day in a warm (ish) room, this is the only way of deoderising......
Posted on Aug 20, 2010
How does one clean inside of freezer which had spoiled meat?
Hello Norm;
My name is peter. I am a retired field service refrigeration technician.
Plastic liners hold odor.
1.) Scrub down the liner with vinegar and water. Place baking soda on the shelves and close the door.
2.) There are special air fresheners for freezers to prevent odor. Sears carries them for about $12.00.
Mar 22, 2015 | Freezers
My freezer isn't keeping things frozen. The inside is cold, but not nearly cold enough. Some packages of meat are spoiling. I hope that the freezer isn't a total loss. I would rath
there may be a gas leak. call the fridge technician and have it checked out.Check that the power plug is in properly and that the point is alive (blown fuse in meter box)
Jan 30, 2015 | Freezers
How to remove the odour of rotten meat from freezer
Clean the inside of the freezer properly with a strong detergent and then, using a very old trick, place an open packet of baking powder or a piece of coal in the freezer to remove any remaining smell.
Jan 17, 2011 | Freezers
How is the best way to get the odor of thawed meat out of a freezer?
CLORINE BLEACH...clorine is a gas and it will dissipate if you leave the door open until dry...(the stronger the better and WEAR
GLASSES.)please dont use "cheap bleach"........
Sep 28, 2010 | Amana 14.9 cu. ft. / 422 liter Chest...
Freezer got unplugged, meat spoiled, freezer cleaned, smell remains. What can we do to get rid of smell?
I have found that the best cleaners for removing left over odors are citrus based cleaners. They help to neutralize odors and prevent re-occurrence. You could also use a diluted bleach as well to sanitize the inside. Make sure it is not too potent or the bleach odor will overcome the bad odor in annoyance.
Good luck!!
Jun 15, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Need correct setting for 30 yr old upright Kenmore freezer
Your best bet is to start in the middle. Guesstimate and let it run. The test is to see if water freezes solid in 6-8 hours. If not, you can turn about 1/4 turn or less. Then you can try hamburger meat which a lower freezing temp and see if it gets solid. Your perishable items should be put somewhere else until you are ready. At least the water frozen will keep the meat safe from bacteria growth or spoilage. Let me know how you do.
Feb 17, 2009 | Frigidaire Upright Freezer FFU12F2H
DEEPFREEZER
The best you can do is ensure that the compressor area and fins are not clogged by dust and such. But don't mess around long, call a repair man to fix your freezer if cleaning doesn't help. Prob cheaper than replacing your spoiled food.
Oct 24, 2008 | Freezers
Frigidaire upright model #MFU20F3GW8- Food not freezing
Check and clean the air cooled condenser for dust and dirt. Check and make sure the fan in back, on the bottom behind a removable panel, is operating. After cleaning the condenser replace the panel.
Also you stated there is no frost anywhere. Did you check the back wall of the freezer for frost buildup. If not check it and if there is frost there your defrost system is not working and the frost has stopped air circulation.
Jun 14, 2008 | Freezers
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
232 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
